Old 08-08-2010, 07:28 PM   #1
ubear7
Drives: 2007 Yaris
A/C blower resistor
My a/c blower fan fluctuates at various times. Sometimes it does not turn on at all. When it does turn on it runs great and cold. I know that the a/c blower speed is controlled by the blower resistor through the fan speed switch. My loaded resistor voltage is 3.5v on 1, 5.2v on 2, 7.6v on 3, 12.1v on 4. My unloaded voltage is 14v. Is this correct or should the resistor be changed?
ubear7 is offline   Reply With Quote
Old 08-08-2010, 09:53 PM   #2
Those sound about right. I haven't measured the voltage, but I have measured the resistance of the three taps on the resistor, which are 1.0, 2.0, and 4.0 ohms. The blower motor has a coil resistance of 5.4 ohms.
High completely bypasses the resistor, so if it sometimes doesn't work on high, then it's definitely not the resistor.
I would check the contacts on the blower switch and also the HTR relay.
Tags
a/c blower resistor
A/C Not Blowing Cold Air...among other things yarisitis DIY / Maintenance / Service 38 07-28-2016 04:00 PM
DIY: Unlink A/C from Defroster stran DIY / Maintenance / Service 46 01-19-2015 09:17 PM
Easy Defrost A/c running fix billk General Yaris / Vitz Discussion 14 01-16-2009 08:53 PM
A/c blower motor noise!!!! LBdriver General Yaris / Vitz Discussion 28 09-12-2007 07:46 AM
A/C blower flighttekchris DIY / Maintenance / Service 5 08-25-2007 11:42 AM
