Y4R1Z
well... sorta
This is really the beginning of the end. I'm waiting on the dynamat to get here. Probably arrive in about 4 hours or so. Decided to go ahead and strip my baby After reading some healthy discussions about sound deadening materials I don't think I'll be trying to cover every square inch of sheet metal. I'll put up some more pics after the procedural work is done ![]() Hopefully I'll be done with this kind of work for good after this! I haven't decided if I want to try to do the doors yet or not. The Fatmat I put on the back half of the car is melting in the Texas summer sun found a couple tiny puddles under the carpet where it ran down the sides. I'm afraid to take off the side panels and check out the extent of the damage. So I might find something else for the doors.
![]() ![]() ![]() ![]() Drives: 2009 Meteorite Metallic LB MT Join Date: Oct 2008
Good luck with the deadening work. Maybe you can answer the question on this post:
http://www.yarisworld.com/forums/showthread.php?t=29753 as it appears that you removed the split seats. |
Y4R1Z
So 35 sq ft of dynamat and a gallon of sweat later, the sun has set and I have a iPhone camera with no flash. The best pic I could get was some sparkle off the shiny backing of the dynamat from the flashlight. So no after pics... But I took it for a spin and noticed a little less road noise. It wasn't as much as I was hoping for, guess I'll be doing the doors sometime.
Roadrunner Jr.
This looks familiar...
“To argue with a person who has renounced the use of reason is like administering medicine to the dead.” ― Thomas Paine |
Y4R1Z
which part?
Roadrunner Jr.
Y4R1Z
nice write up sqcomp! You were extremely more thorough than I was. Good Job!
![]() ![]() Drives: 3dr Lftback (meteorite) Manual Join Date: Apr 2010
You may already know this... the dynamat will reduce vibration. if you want to reduce noise you will need to get a Mass Loaded Vinyl barrier down. MLV acts like the big cement barrers that go along the freeway. blocks sound. To the extent that the vibrating metal in your car is producing noise the dynamat will kill that. to block out road noise... that's the job of MLV. you can also use a Closed Cell Foam (CCF) to absorb some of the remaining noise as well.
and that is just the beginning. Sqcomp's thread is fantastic! another site that i have found helpful in my education is http://www.sounddeadenershowdown.com just some thoughts. |
Y4R1Z
I'll check it out.. when it cools off in texas. I'm sick of working in 100+ heat while sun cooks me alive in my black yaris :(
I need to wait for a more wintery project ;) |
| Tags |
| deadening, dynamat, insulation, sound |
| New to Yaris ? Check in here !! | VitzBoy | General Yaris / Vitz Discussion | 1960 | 02-02-2026 10:14 AM |
| Twin Charging | whooppee777 | Forced Induction Forum | 68 | 04-28-2009 07:02 PM |
| And it begin's.... | punch | In Car Entertainment + Electronics (audio / video / alarm) | 9 | 08-17-2007 09:34 PM |
| Ordered mine today... now the wait begins | boris13 | New YARIS Purchase Forum | 1 | 11-10-2006 07:40 PM |
| The countdown begins! | Slummy | New YARIS Purchase Forum | 6 | 08-30-2006 04:36 PM |
