Old 01-21-2007, 12:15 PM   #1
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
Got new wheels, tires, and springs installed.
Specs -
16X7 Bronze Konig Heliums
205 50 16 Falken Zeix 512
Black gorilla splinedrive lugs
Springtech springs 1.7 in drop F\R
I am going to put in the center caps, but I am painting them black first.
The car rides very well with these springs. Just changing the wheels and tires was a noticeable improvement in handling. The car felt more stable and consistent. Adding the springs just tightenend up everything a bit more. The ride is great with the stock struts and these springs. I wanted these over the Tanabes because the Tanabe DFs lower the rear too much for my taste.
I got the wheels and tires from JLB Motorsports in Corona, CA http://www.jlbmotorsports.com. They did great work and gave me an excellent price on the wheel and tire package. They do alot of businees on ebay and some other forums. I highly recommend them.
Ashley
Old 01-21-2007, 01:27 PM   #2
St_G
Drives: Black 2007 Yaris Liftback 1.5
That looks really great, actually. I'm with you in that I prefer the look of the lowering kits that keep the F/R geometry the same. The ones that lower the rear an extra few tenths of an inch somehow (and I can't quite explain this) end up looking more generic and plain. And the bronze wheel looks very nice against the silver.
Now go get some foglights!
St_G is offline   Reply With Quote
Old 01-21-2007, 02:59 PM   #3
tekmoe
ex-yaris owner
Drives: 08 solstice gxp, 06 triumph s3
Send a message via AIM to tekmoe
very nice. i kinda wish i woulda went with the 205/50 profile on my 16's. ah well, maybe next time.
tekmoe is offline   Reply With Quote
Old 01-21-2007, 03:26 PM   #4
Go4th
Go4th's Avatar
Drives: Yaris S Sedan color Flint Mica
Looks good! If i had a silver car i would have been scared to do it untill i seen it some where. The bronze wheels really go great. The drop is perfect!
Go4th is offline   Reply With Quote
Old 01-22-2007, 12:00 AM   #5
LVAquaman
LVAquaman's Avatar
Drives: 2007 Yaris Hatchback
Your car looks great!
LVAquaman is offline   Reply With Quote
Old 01-23-2007, 03:34 PM   #6
kngrsll
Apexing Egg!!
kngrsll's Avatar
very cool...
HighTach Motorsports
2007 Toyota Yaris-ARGH!!
Old 01-23-2007, 05:21 PM   #7
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
Just out of curiosity, Why did you choose Spring Tech springs? Do you like them? Car looks good.
Old 01-23-2007, 05:33 PM   #8
BokChoi
Mada Mada Dane...
BokChoi's Avatar
Drives: Toyota Yaris LB
do the heliums come with the center konig cap?
My Car
My Garage
BokChoi is offline   Reply With Quote
Old 01-23-2007, 06:55 PM   #9
bigsky2
Cousin Vitz
bigsky2's Avatar
Yes, Heliums come w/ center caps.
Old 01-23-2007, 07:02 PM   #10
rwseattle
Rwseattle
rwseattle's Avatar
Drives: 2007 Toyota Yaris (BASE)
Question
Very nice. I'm waiting for my 16" rims and will post pictures after they arrive. Q: Did you order the 16" because it rides better than 17" or 18"?
rwseattle is offline   Reply With Quote
Old 01-23-2007, 09:42 PM   #11
501
Drives: 07 yaris
great job on the look
'07 blazing blue hatch-TRD shocks-tanabae df210-TRD rear sway bar-koning feathers 16x7-the basics for now
501 is offline   Reply With Quote
Old 01-23-2007, 10:07 PM   #12
largeorangefont
Break'em off some.
The springs are great, and ride pretty well. I went with the Springtechs because it is an even drop front to rear. The Tanabe DFs lower ther rear more than the front in some of the cars I have seen, and I don't like that stance.
Old 01-23-2007, 10:09 PM   #13
largeorangefont
Break'em off some.
Yes they do. I am going to paint them black when I have time. I think it will fit the theme better.
Cheaper tires, and a better ride were both factors. Plus I didn't want to sacrifice any fuel economy. Also I didn't want to spend $1000 on a set of lightweight 17s. My setup is only a couple pounds heavier per corner than the stock 15s.
At this cars weight and power level 14-15 inch wheels and good tires will yeild the best handling.
Old 01-26-2007, 11:36 AM   #14
rwseattle
Rwseattle
rwseattle's Avatar
Your car looks good. I ordered gunmetal wheels but the gold looks nice. My tires size in 205/45/16 and will probalby lower the car 1.8 or 1.9. that will create the same look. Thank you. Pic later.
Old 02-02-2007, 01:45 AM   #15
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Cool schweet ride
awesome car, dude...!
great drop... kinda makes me think about getting the springtech's instead of my planned NF210's...
i'm also thinking on going for bronze wheels, although I'm leaning more towards the ssw trex 16's:
still in the early stages of window shopping though, so things may change drastically in the future... i.e. right now my ideal tire setup is 205/50/16, although i may just go for some 215/45's, which would probably rule out getting those wheels in the first place...
decisions, decisions, decisions... :)
Old 02-02-2007, 04:39 PM   #16
largeorangefont
Break'em off some.
still in the early stages of window shopping though, so things may change drastically in the future... i.e. right now my ideal tire setup is 205/50/16, although i may just go for some 215/50's, which would probably rule out getting those wheels in the first place...
Thanks!
Just an FYI, the 215s may rub a bit more than you would like on hard turns or big bumps if you go with a lower spring (DF,Springtech Tein etc.). With the TRD springs or the NFs you should be fine. My 205s rub just a bit in these situations and swaybars and/or sturts should fix it.
Old 02-06-2007, 04:26 PM   #17
bigsky2
Cousin Vitz
bigsky2's Avatar
largeorangefont - ashley:
I really like the colour of your wheels. Do you find that the colour changes depending on the lighting around the car?
I ordered the Konig Helium in 17" last year, Bronze colour.
See Thread: http://www.yarisworld.com/forums/showthread.php?t=1264
When opened, they were not very bronze, but more gun-metal!
I do wish my wheels were a little more bronze than gun-metal, especially after seeing yours. But it could be because of the lighting issue.
Just a friendly note to those who are interested in Helium 17's - verify the colour first! It seems the "bronze" colour is consistent among the 16 and 15's I've seen so far.
Old 02-06-2007, 04:41 PM   #18
largeorangefont
Break'em off some.
In the dark, these could be mistaken for gunmetal but when there is any light at all they are clearly bronze. The pictures I have seen of this wheel are accurate to what you see in person.
These are a very deep, dark,bronze. In fact, these are the darkest bronze wheels I have owned. I have had some bronze Rotas and 5Zigen wheels before and like this dark bronze on the Heliums better.
Hope this helps.
Ashley
New 07 Yaris S need advice on 18's and springs OgDogg Wheels, Tires and Suspension Forum sponsored by The Tire Rack 48 04-27-2009 09:50 PM
Got new wheels, tires, and springs installed. largeorangefont Photo-Video-Media Gallery 8 01-22-2007 04:29 PM
Just put my new wheels on Ryosuke Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 07-18-2006 01:04 AM
Lets talk wheels birdy Wheels, Tires and Suspension Forum sponsored by The Tire Rack 80 04-29-2006 01:13 AM
