Old 08-11-2010, 07:59 PM   #1
Focus_Sh1ft
Focus_Sh1ft's Avatar
FIC Wiring Help
Today I went to go wire my FIC up, but got kinda confused... This ECM pinout I'm using has got me all sort of confuzzled. Check it out here:
http://www.powerenterpriseusa.net/pr...risControl.pdf
Firstly, everything has two different wires listed and I have no idea what the acronyms stand for. So basically, I have no clue which wires I should be using to tap/intercept. It looks like some things are listed as + and -, while others aren't. Here's what I think needs to be done...
FIC Power - A21-1 or A21-2
FIC Gnd - C20-104
Injector 1 - C20-108
Injector 2 - C20-107
Injector 3 - C20-106
Injector 4 - C20-105
MAF+ - C20-118
MAF- - C20-116
Old 08-11-2010, 11:15 PM   #2
Connectors A21 and C20 are the two ECM connectors. The drawings above are looking into the connectors with them removed from the ECM.
What's listed is Function, Connector-Pin
The MAF also has polarity listed +/-
FIC Gnd - C20-104
MAF+ - C20-118
MAF- - C20-116
Old 08-12-2010, 12:12 AM   #3
Focus_Sh1ft
This is what I figured. So I was actually correct??
Two things I don't understand then. What's the difference between +B and +B2 on the power source? And is E01 (C20-45) (injectors) kind of like the ground for all four injectors?
Old 08-12-2010, 11:26 AM   #4
There's no difference between +B and +B2 (the two pins are connected together inside the ECM). E01 is the common for the injectors.
Installing Trailer Light Harness vandallen DIY / Maintenance / Service 7 06-10-2024 11:06 AM
Wiring Pictures MitchEvious In Car Entertainment + Electronics (audio / video / alarm) 2 12-28-2009 12:43 PM
AEM FIC works perfectly cdydjded Performance Modifications 58 08-03-2009 07:20 AM
Wiring color code for 2008 LB? charles nelson DIY / Maintenance / Service 0 04-25-2009 04:56 PM
Pioneer AVH-P4000DVD Wiring Adapter?? maxiMOOM In Car Entertainment + Electronics (audio / video / alarm) 2 02-11-2009 02:11 PM
