Engine Speed Sensor Location?
Where is it? I'm talking about the RPM sensor that send the speed data to the ECU...Or even better, does any one have a map of all of the sensor locations on a 1nz? thanks,
- H
Toyota Moving Forward ...even when you don't want it to. Special thanks to Cali Yaris, 1NZYaris1 and lilredrocket
![]() ![]() ![]() ![]() Drives: Yaris LB Turbo Join Date: Aug 2006
It's under the backside of the pulley. Look for a big black connector with tape on it.
Drives: Yaris 2DR LB 07, MT, Abs. Red Join Date: Feb 2009
sorry, better luck next time !
Thanks Cdy...here is the info for the next guy:
"The Crankshaft Position (CKP) sensor system consists of a CKP sensor plate and a pickup coil. The sensor plate has 34 teeth and is installed on the crankshaft. The pickup coil is made of wound copper wire, an iron core and magnet. The sensor plate rotates and, as each tooth passes through the pickup coil, a pulse signal is created. The pickup coil generates 34 signals per engine revolution. Based on these signals, the ECM calculates the crankshaft position and engine RPM. Using these calculations, the fuel injection time and ignition timing are controlled." And location:
#7 | |
![]() ![]() ![]() ![]() Drives: Vitz RS Turbo Join Date: Nov 2008
Does this sensor relates to the Crank Trigger? Does the crank trigger is 34 on our 1NZFE? |
I think you mean:
A) Is this the sensor same as a crank trigger? (yes) B) Is the signal 34 pulses per revolution? (yes)
I don't know maybe the image is illusrated wrong since mine the crank sensor is at the lower left of the engine and not in the middle as shows the image.
See below attachment Can you confirm is the same sensor? |
You're view the image in the wrong contexts. The view shows the sensor by looking through the motor and is indeed in the lower left corner of the block.
Thanks better sure than disappointed
Sry I'm just getting to this...Bluevitz is correct. You need to be thinking in terms of X-ray vision.
TRD TURBO
Drives: TRD VITZ TURBO 2003 Join Date: Aug 2010
i need to connect a vehicle dynamic processor from pioneer. which of these sensors can i get the vehicle speed signal from?
The Vehicle speed sensor comes out'a the transmission.
![]() Drives: TRD turbo vitz Join Date: Aug 2010
May I know what is the colour of the wire and where it si found exactly( Diagram or picture please)
I replied to your PM, what year is the car?
its a 2003 Vitz TRD Turbo
No need for the PMs...
It's a purple wire, but I don't have my EWD on hand to tell you what connector... I'll see If I can find it. Edit: ok found it. I have a '04 manual, so as long as you have a 4 connector ECU it should be the same. It's a purple wire with white tracer, pin 17, connector B. |
| DIY: Intake Installation | redyaris | DIY / Maintenance / Service | 53 | 08-23-2014 05:34 AM |
| Remote Engine Start PT398-33070 | Reeves360 | In Car Entertainment + Electronics (audio / video / alarm) | 3 | 08-26-2009 07:11 PM |
| Engine intake air flow not smooth on certain speed and gear? | ammophobia | DIY / Maintenance / Service | 3 | 07-17-2009 03:31 AM |
