Old 01-23-2007, 08:37 AM   #1
Go4th
Go4th's Avatar
Drives: Yaris S Sedan color Flint Mica
Exclamation CLUSTER LIGHTS WENT OUT
The cluster lights (tach, speed, o etc area.)
I started my car this morning let it warm up 10 or so mins.
Got in turned on my head lights and when I put the car in reverse to leave the drive way BAM there went the cluster lights on the dash.
I thought WTH..
I reached down on the left side dash area where the dimmer switch is for the cluster lights and it was all the way up (full bright) I turned the dial down past the notch grabbing part where it starts the dimming process for going dimmer and dimmer too off and it came back on.. I turn the dimmer all the way down and its dark and start the dimmer up and it gets brighter and brighter but when I go past that notch bump area for full brightness it goes out again.. Any one had this problem????
Go4th is offline   Reply With Quote
Old 01-23-2007, 09:03 AM   #2
what happens if you turn off the headlights?
Old 01-23-2007, 09:09 AM   #3
Blenjar
Blenjar's Avatar
Drives: Black Yaris 07 HB
ouch...
-- Blen
Old 01-23-2007, 10:04 AM   #4
Go4th
Go4th's Avatar
they stay off.. nothing...
ohh.. i have done 0 "zero" mods thus far. so nothing i did caused this..
Old 01-23-2007, 10:11 AM   #5
well then, straight to the dealer you go
Old 01-23-2007, 10:18 AM   #6
Go4th
Go4th's Avatar
JOY
JOY, brand new car.. just what i need some one else tearing it apart and messing up something and having a never ending mess...
Old 01-23-2007, 11:54 AM   #7
tiksman
tiksman's Avatar
Drives: 07 Red Hatch
A few months ago some peeps here on the board were having trouble with the headlight switch. Maybe that is your issue also.
tiksman is offline   Reply With Quote
Old 01-23-2007, 12:41 PM   #8
uncleyaris
Pack a lunch when you go to the dealership. It maybe a long haul. Gotta just piss you off though.
UY
Old 01-23-2007, 01:03 PM   #9
Go4th
Go4th's Avatar
I will have to try to find those threads. Thanks
UY
Yup.. I am not looking forward to taking my brand new car to the dealership with an electrical problem..
Old 01-23-2007, 04:17 PM   #10
Go4th
Go4th's Avatar
Thumbs up Solved
Problem solved after I went to the dealership.
I must have hit the switch cleaning the car.
Apparently all our Yaris' all shut off the cluster lights when you run it all the way up.
From the day I purchased the car it must have been on the full dimming area up and not past that little notch area.
Even though our cars have a picture on the damn dial that shows the more up you roll the roller the brighter it gets and then a picture that shows the instrument panel lit up, must be wrong.
I guess everyone can go try it and see.
Turn on your head lights roll the roller up and watch the dimming console get brighter and brighter and then go past that little notch area and when you’re expecting to see the cluster panel be its brightest it cuts off.
Some cars, when you get to that point and go past the notch it will turn on the dome light. And apparently what ever car they put that system in and the dome light comes on and it kicks off the cluster panel so you can see it when your driving at night with the dome light on. Is all i can figure.
Old 01-23-2007, 11:22 PM   #11
I still thisnk you have a problem...
See the attached file, it's a section from the technical manuals, it should be at full nighttime brightness, after the wheel clicks, not off...
Sounds to me like the dimmer rheostat might be the cause of the problem.
Old 01-24-2007, 08:40 AM   #12
punch
punch's Avatar
I also think you have a problem, i will check mine tonight, but the owners manual says the upper position will illuminate the gauges, and not dim them when the headlights are on etc.. (read it yourself)
also try another car at the dealers to see if it's the same..
punch is offline   Reply With Quote
Old 01-24-2007, 11:09 AM   #13
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
Same here.. i keep mine at full lock (UP) position, and they are always on max bright, day or night.
Old 01-24-2007, 05:16 PM   #14
Go4th
Go4th's Avatar
I will read it! The dealership brought a car around it did the same thing.. the car was a runner car it had some miles on it from the parts dept use..
I swear, I am almost convinced i saw it go out when i was backing up. But they had me almost convinced other wise when they brought that other car around.. I dont think i am loosing my mind..
Thanks
Old 01-24-2007, 06:48 PM   #15
punch
punch's Avatar
Thanks
ok i went and checked mine and yup, when you go passed the indent on the scroll wheel, the cluster does GO OUT, and the area for the trip meter goes full bright, so it is acting the same as yours, i have a sedan, and live in Canada. This function is for driving in bright daylight, since you don't need the gauge lights, but want to be able to see/read the trip/fuel meter. NORMAL!
I notice Chris07lb, has a hatch, maybe there different.
Old 01-24-2007, 07:01 PM   #16
Go4th
Go4th's Avatar
o really?!!
this is crazy.. lets see what others post and the type of cars they have and location and maybe we will see if its a lb or sedan or country thing.. b4 i go to the dealership again.. whats going on?
others please check your car and post the results please..
Old 01-24-2007, 08:57 PM   #17
BMGYaris
Drives: Yaris 3dr Hatchback
I have a LB U.S.
I always leave mine in the position past the little notch, it leaves my clusters on full bright when head lights are off (which is pretty much never), and then dims when turn on my headlights. I had always thought that it was to allow maximum visibility during daytime when glare on the glass could pose a problem seeing the cluster, but at night it dims to prevent the lights from distracting or causing any kind of vision hinderance at night. Afterall, the more lights in your cabin at night the harder it is to see out, and the cluster is def. visible at night without the brightest setting. So have i been wrong in my assumption?
BMGYaris is offline   Reply With Quote
Old 01-25-2007, 07:44 AM   #18
d2dailly
Roar?
Drives: 07 White LB Yaris
Send a message via AIM to d2dailly
everyone with a sedan it turns off when you go to the lock position, everyone with a LB it turns full bright when you go to the lock position
d2dailly is offline   Reply With Quote
Question about lights kaymm General Yaris / Vitz Discussion 4 04-20-2020 09:10 PM
Smoke your own tail lights ChinoCharles Cosmetic Modifications (Exterior/Interior) 9 01-15-2007 11:00 PM
Shift knobs with lights? IsLNdbOi Cosmetic Modifications (Exterior/Interior) 0 09-20-2006 04:09 PM
can i / where to get factory switch for aftermarket fog lights? and exhaust tip q. fantabulousbaby Cosmetic Modifications (Exterior/Interior) 22 08-29-2006 01:13 PM
Fog lights for S sedans (US version) paeko73 General Yaris / Vitz Discussion 11 07-02-2006 11:38 PM
