![]() Drives: 2010 Sedan - Automatic - White Join Date: Jun 2010
Road debris destroyed one of my OEM Bridgestones. (less than 10k on tires)
Is there a tire pressure sensor in the tire itself, as well as one on the stem? And can they all be used (and easily removed/reinstalled) with the new replacement tire? I'm more than 2 hours from the nearest Toyota dealer so I plan on using a local shop after receiving my replacement tire from Tire Rack. Thanks in advance. |
The sensor is part of the valve stem, so you should be OK.
Thank you very much.
Just make sure the tire place doesn't F-UP the sensor when they're dismounting the tire. Make sure to let them know its there.
| tire noob question..what's the widest tire size can run on stock 15"s? | detroiter | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 22 | 12-06-2011 09:44 AM |
| recurring loss of tire pressure | toad | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 14 | 12-10-2009 04:54 PM |
| Tire pressure sensors | ztlonewolf | DIY / Maintenance / Service | 14 | 04-25-2009 05:19 PM |
| Higher Tire Pressure | captainm27 | General Yaris / Vitz Discussion | 46 | 01-27-2009 10:17 AM |
| The Tire inflation debate... | Tankota | General Yaris / Vitz Discussion | 20 | 06-01-2006 07:09 PM |
