Old 10-28-2006, 01:23 PM   #1
eflb55
its EF LB 55
Drives: Toyota Yaris 2007 Sedan (US)
multisession discs in headunit?
Yesterday I added like 10 new mp3 songs to an mp3 cd that had about 40 songs on it. If I open it on my computer it shows the new songs but when I go through it in my stock head unit they don't show up. I used nero to burn the initial 40 and just chose the burn mp3 cd again to put on the other 10. Do I need a specific type of cd or maybe a different format for burning cds?
btw, i have the american hu that comes with the power package
eflb55 is offline   Reply With Quote
Old 10-29-2006, 01:50 AM   #2
07WYarisRS
HardlyDangerous
07WYarisRS's Avatar
Drives: 09 Yaris LE, H/B, auto
Try putting then in their own seperate folder, and not just in with the rest.
or maybe you put them in a new folder and you are just not scanning through the folders on you HU?
The early bird gets the worm, but the second mouse gets the cheese.
07WYarisRS is offline   Reply With Quote
Old 10-29-2006, 03:49 AM   #3
eco
eco's Avatar
Drives: 2007 Black Yaris sedan
Ya,multi-session disc's is are hard to handle on alot of diffrent players,some wont play on dvd players,or home cd players.The reason being,the disc is actually finalized on the first session,your just using the rest of the space to write the other session,a computer can easily handle reading this type of disc,but a car HU cd player on a semi-cheap car will choke;Because it can only see one session,or think of it this way,its like your trying to put in 2 cd's at once,but the HU is only programmed to see 1.Try not using multi session,if you want just mp3's on the cd,just make a data cd and dont finalize it,alot of players will see the mp3's anyway,then just add mp3's to that data disc.
eco is offline   Reply With Quote
Old 10-29-2006, 10:40 AM   #4
07WYarisRS
HardlyDangerous
07WYarisRS's Avatar
Good point
I don't use any burning programs to make a data CD
Just copy the file click on the drive your burner is in and paste it then burn it.
Old 10-29-2006, 12:26 PM   #5
eflb55
its EF LB 55
o ok ill give it a try
edit: I burned it under a data disc and then burned another track to it and that track didnt show up
Old 01-19-2007, 11:51 PM   #6
manborn
are u still 34/39?
manborn's Avatar
Drives: flint mica yaris s sedan
are there firmware upgrades for the stock head units so it can support multisession and maybe more compatible with different brands of CDRs?
manborn is offline   Reply With Quote
Old 01-20-2007, 12:40 PM   #7
spkrman
Drives: 1
cdr's are cheap, just burn a new cd :)
Old 01-25-2007, 05:10 AM   #8
eijikikimaru
Q(','Q)
eijikikimaru's Avatar
Drives: 3dr Meteroite
A little off subject but has anyone else notice that when the song random is hit, and then repeat, it goes thru the same list of songs.
My cd containing over 100 songs just go thru the same 9 tracks
eijikikimaru is offline   Reply With Quote
Old 01-25-2007, 03:57 PM   #9
eflb55
its EF LB 55
Thats the defect that pushed me over the edge to get a new stereo. I can't stand it at allllll. Drove me insane. Just crappy programming on the manufacturers side. I have a feeling the random number generator is pre-set for each time you put the cd in, not every time you switch the song.
Old 01-26-2007, 12:17 AM   #10
St_G
Drives: Black 2007 Yaris Liftback 1.5
I haven't had much need to use the CD player, really. I've got a mx disc in there right now, just 'cause I wanted to give it a couple of listens before I passed it on to a friend (I'm anal about my mixes), but mostly I just use the AUX input to listen to my iPod while I drive.
St_G is offline   Reply With Quote
Changing drum brakes to discs? eTiMaGo Performance Modifications 5 09-25-2006 04:17 PM
Trim/Dash Kit (for single DIN headunit) for Yaris yet? bigsky2 In Car Entertainment + Electronics (audio / video / alarm) 46 09-01-2006 07:30 AM
