Old 09-25-2010, 12:38 PM   #1
mhkritzinger
Drives: 1.8 3dr Yaris TS
Reset EMS?????
HEllo...
I'm just wondering if their is a way so that I can reset the cars computer without going to a dealer?
Thanx!
mhkritzinger is offline   Reply With Quote
Old 09-25-2010, 01:11 PM   #2
severous01
the best way is to get a scan tool and delete codes.
second and worst idea out of all of them but probably the cheapest and easiest...disconnect negative terminal from battery and apply it to the pos cable for about ten minutes. go back and plug her up. this will delete all driving history and you'll get really crappy mileage for about 500-1k miles. but, if you're havin weird hard to chase problems, this will likely fix it if it's module related and not end product related like a regulator or whatnot.
Old 09-25-2010, 01:17 PM   #3
^ Shouldn't we ask why you want to do it first?
Old 09-26-2010, 03:47 AM   #4
mhkritzinger
Well the last service i did on my own. the cars cold start is a bit funny. it sounds like when you start the motor the motor doesn't start up as it should and then the starter motor does not disengage fast enough. so i don''t have the tools to reset the ems after it has been serviced.
any advice?
Thanks for the replies!
Old 09-26-2010, 03:53 AM   #5
rningonfumes
rningonfumes's Avatar
Drives: Yaris Sedan 5MT
hmm... Because you are in South Africa there may be a difference in terms, what does EMS stand for in your part of the woods? You don't mean the maintenance?
Old 09-26-2010, 05:11 AM   #6
mhkritzinger
EMS engine management system
Help me decide which EMS Yoda Performance Modifications 16 08-14-2010 05:10 PM
How do I reset maintenance light? Snake DIY / Maintenance / Service 10 06-04-2010 12:57 PM
how to reset the vitz car remote mehmood sheikh General Yaris / Vitz Discussion 3 05-03-2010 01:50 PM
Got an EMS package today with... Brian Cosmetic Modifications (Exterior/Interior) 8 04-06-2010 04:40 AM
Does Toyota reset the speedo for the Yaris that have 14" and 15" rims? detroiter General Yaris / Vitz Discussion 19 05-17-2009 08:46 AM
