Ooby Dooby Ke-Newbie
Drives: 2007 Yaris Sedan Join Date: Dec 2006
System is installed!
Well, it took a lot of work, but we finally got the system installed.
The head unit is a JENSEN VM9021TS 6.5" LCD TOUCH SCREEN We put two ALPINE SPS-69C3 3-WAY 6"x9" S-TYPES in the back For the doors, INFINITY KAPPA PERFECT 6.1 6.5" COMPONENTS- On these I ended up mounting the tweeters on the dash, and the crossovers behind the glovebox. I'm not sure if I like the look of the tweeters, but they sound very nice bouncing off the glass. To run those speakers, we mounted an Inifinity 7541a, 4 Channel amp under the pasengers seat...a very tight fit. For a little boom, We put an Infinity Kappa Perfect 10" Sub in a Q-Logic box in the back. To run the sub we mounted an Inifinity 611a, Mono amp under the trunk deck. It looks very nice and clean. For added power and so the headlights won't dim, we put a Rockford Fosgate Capacitor in front of the bask seat, hidden behind the plastic molding. That's also where we mounted the fuse box for the dual amp wiring kit. I haven't installed all the door lock actuators yet, so until that's done I can't put the dynomat on, but once I do it should be all finished up! It sounds great! Now I can listen to classicl music at ear splitting levels!
Man this is quite the day for you isn't it.
Sorry, but somebody has to do it... ![]()
Me 2, I installed my shark antenna...but I haven't installed my fogs or mirror signal yet..:'(
I got paid today tho..might go get that remote start/alarm.. -- Blen
http://www.360voice.com/tag/noobblenjar ![]() My Car http://www.yarisworld.com/forums/showthread.php?t=4245 My DJ www.PainlessWolf.com |
![]() ![]() ![]() Drives: 2007 3 dr manual Join Date: Apr 2006
Be careful with the amp under the trunk deck. If it's how I think it is mine was installed like that and within a week the screws gave out and it fell into the spare tire lol. But then again it's about 25 pounds
![]() ![]() ![]() ![]() ![]() Drives: 2007 Bayou Blue!!!!!!! Join Date: Nov 2006
pic's man! lets see this masterpeice.
UY |
![]() ![]() ![]() Drives: 2007 White Toyota Yaris Type S Join Date: Dec 2006
[QUOTE=Venom;49614]
That's also where we mounted the fuse box for the dual amp wiring kit. [QUOTE] Id recommend mounting that fuse in the engine bay......its a little safer that way....... |
#7 | |
[QUOTE=07typeS;49753][QUOTE=Venom;49614]
That's also where we mounted the fuse box for the dual amp wiring kit. Quote:
Drives: Black Join Date: Jan 2007
Dude where are the pics?
My problem with pics is that my home computer is down right now. But I'll be moving this week and will have a working computer then. I'm on my work computer now, and can't upload pics to it. Be patient!
[QUOTE=Venom;49815][QUOTE=07typeS;49753]lol what you mean it makes no sense.....dude if you have a short you want to fuse it as close to your battery as possible......heat.....spark......fire.......check all recommendations on fuses, they all recommend they be mounted within i believe its 18 inches of the battery.......
#12 | |
![]() ![]() ![]() ![]() Drives: 2007 Yaris Sedan "D" package Join Date: May 2006
[QUOTE=07typeS;51595][QUOTE=Venom;49815]
Dude, i'm sure he has a main fuse on the main wire at the battery, the wire then goes to his "fuse box" in the rear of the car where he can then split the thicker wire to power his amps.. |
Cousin Vitz
Drives: Yaris RS 5DR / Vitz RS wannabe Join Date: Mar 2006
Main fuse up front by the battery, "fuse box" - better known as a power distribution block, can be mounted at the rear to supply power to multiple amplifiers and components.
I don't think anyone would neglect having a fuse near the battery if they've done some homework.
DIY Speaker Spacer/Bracket Template for Yaris Hatchback http://www.yarisworld.com/forums/showthread.php?t=1930 |
The last two post are dead on. Sorry if I confused any of you.
yea see thats what confused me.......the distribution block is fine back there, and your right it would make no sense that have it in the engine bay lol......now that were all good, nice choice on speakers, i have the exact same set up except i got 5 1/4's upfront, and 12" kicker comp sub and my speakers are running off the deck right now.....it doesnt sound 1/2 bad and i may leave it that way......
| Fiberglass enclosure / Stereo system | bugnuts | In Car Entertainment + Electronics (audio / video / alarm) | 30 | 05-20-2007 12:11 PM |
| Immobilize and security system. | Meow | In Car Entertainment + Electronics (audio / video / alarm) | 19 | 04-18-2007 05:40 PM |
| Tanabe NF210's installed...got a question though | Terrorize | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 32 | 09-29-2006 07:45 AM |
| My Sound System | mhero | In Car Entertainment + Electronics (audio / video / alarm) | 0 | 09-18-2006 11:50 PM |
| Question about Toyota's shipping system | Goose | New YARIS Purchase Forum | 4 | 04-30-2006 11:03 AM |
