Old 10-05-2010, 05:42 PM   #1
The Spectacle
The Spectacle's Avatar
Drives: 08 BSP LB
Hardwire garage door opener
Anyone on here every done it with their Yaris? I plan on doing it soon, just not sure what I'm going to use as a trigger. Suggestions?
The Spectacle is offline   Reply With Quote
Old 10-05-2010, 05:45 PM   #2
ezhacker1
ezhacker1's Avatar
Drives: Decepticon - Ravage
Simple momentary switch connected to where the original switch is i guess would be easiest.
Or be crazy and have it sense your car's approach and door opens automatically.
Check out my Build thread:
Old 10-05-2010, 06:48 PM   #3
Palmer812
Drives: 2010 Meteorite Metallic LB
I did one on my motorcycle using a momentary push button from an alarm.
Palmer812 is offline   Reply With Quote
Old 10-05-2010, 08:44 PM   #4
Revsson
Is this what you are talking about?
DIY Stealth Garage Door Opener Button
Old 10-06-2010, 09:57 PM   #5
The Spectacle
Drives: 08 BSP LB
^ Yes. Thanks for the link
Old 10-09-2010, 11:17 AM   #6
Lil Abner
Drives: 2009 3dr LB Manual
I actually got a HomeLink module from the junkyard, took the buttons and LED out, extended the wires, and put the buttons in a blank by my e-brake. The module is up under the gauges. Works great, plus I can re-program it for anything I need.
Old 10-09-2010, 07:26 PM   #7
Revsson
Where do I find out more about the Homelink module and how it works?
Are you re-programming that module?
Old 10-09-2010, 07:42 PM   #8
Lil Abner
HomeLink is something found in a lot of vehicles today, integrated into the rear view mirror, the sun visor, the headliner, etc, etc. It can be programmed to any garage door opener as well as remote light controls. The idea originally was that a person could pull into their driveway, hit one button to turn on the front lights, then hit the garage door button. Only the garage door part stuck, as the house lighting wasn't popular.
I attached some pics of one of the modules I got at a junkyard. You can see the buttons in the console.
This is the HomeLink logo:
This is the removed module:
These are the buttons that need to be unsoldered and wires connected for extending it. I also extended the LED which is used for programming:
And here is my new opener that I made. It's rubber buttons from something else, with a new circuit board with switches under it. Sorry, the second picture is blurry:
Now, this is an easy project if you can solder and have patience!
Old 10-09-2010, 08:39 PM   #9
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
the big problem with that though is garage door openers have gone to a random billion or trillion+ code rotation, so that only works with older garage door openers now.
Colin Chapman disciple
Old 10-09-2010, 08:57 PM   #10
Lil Abner
I don't know what the new ones are, but I have Lift-Master openers, 2 are brand new, and mine works on them. You're right, you'll have to read the manual first.
DIY Stealth Garage Door Opener Button PatrickJohnson DIY / Maintenance / Service 38 10-08-2010 03:42 PM
Penguin Garage Rear Hub Spacers!! Penguin Garage Sponsors Classifieds Area 92 09-02-2009 07:16 PM
Penguin Garage Rear Hub Spacer Raffle!! Penguin Garage General Yaris / Vitz Discussion 27 06-30-2009 02:05 AM
****Kami Speeds 09 Garage Sale/Meet****, up to 60% off everything in stock!!! SAKU Southeast 19 06-28-2009 10:28 PM
Need help finding a garage remote Lafiro In Car Entertainment + Electronics (audio / video / alarm) 7 11-26-2006 11:14 PM
