Old 10-04-2010, 01:11 AM   #19
pspeezy
Drives: 09 Yaris Sedan
ive already ordered my hid kit & eye lids off of MI, so now i just wait for them to be shipped before i can put those suckers on.
the next thing on my list i want to do is put LED lights in my interior, also the two lights above my back license plate for exterior.
ive been trying to find a bundle, or even just the bulbs themselves on the link you posted but i cant find them at all, i am very bad with these kind of things
would you mind directing me in the right location to buy these lights?
pspeezy is offline   Reply With Quote
Old 10-04-2010, 01:24 AM   #20
chrisj
Hooch Brewer-Shine Sipper
chrisj's Avatar
Drives: 2009 5-dr LB
Well pspeezy, I got all mine from SuperBrightLEDS.com. Here is the link where you start. I got all the bulb sizes from elsewhere on the forums here, then just started finding them on the LED site. I bought my dome LED from ebay a month or so ago, but they have it on SuperBright as well (24 LED cluster was what I got). I got 2 map lights, one festoon cargo light (you have a sedan, so not sure about that one), plus I got the license plate light, and my LB has only one.
Here is the link to get started from (where I got mine)
http://www.superbrightleds.com/cgi-b...sp=%2F1157.htm
I got the map lights from this link: http://www.superbrightleds.com/cgi-b...ini-wedge.html
I might reorder some brighter ones though. I think I got 6 LED and I could get 12.
My cargo light was here: http://www.superbrightleds.com/cgi-b...2Ffestoon.html
I got the 6-pack on that one.
You can also get the license plate LEDs from that link for the map lights, I think.
Hope this helps.
chrisj is offline   Reply With Quote
Old 10-04-2010, 01:28 AM   #21
pspeezy
ahhhh! words my brain understands! thanks a ton chris!
Old 10-04-2010, 01:34 AM   #22
chrisj
chrisj's Avatar
yw! Just be careful ordering because there are TONS of bulbs on that site...to make sure you get the right thing. It was confusing for me a little, and I was relieved when everything went fine when I got them in. Everything fit and worked perfectly.
Old 10-05-2010, 02:11 AM   #23
pspeezy
edit: nevermind i figured out exactly what lights to order finally :) i learned how to cross reference and all that jazz
Old 10-05-2010, 08:57 AM   #24
chrisj
chrisj's Avatar
Once you get the types you need and get them installed, then you can take a look at other things like brightness (more or less LEDs in the cluster) and colors. Now that I have mine in, it would be a snap to change out to colors, but I may go up in brightness on my map lights some. The bulbs are fairly inexpensive.
My next thing will probably be footwell lights, maybe installed under the front seats.
Old 10-05-2010, 10:42 AM   #25
big lo
big lo's Avatar
Drives: 2007 VIOS
Good job!!!
Old 10-05-2010, 04:43 PM   #26
ezhacker1
ezhacker1's Avatar
Drives: Decepticon - Ravage
Originally Posted by chrisj View Post
Here are a few pics. They suck a bit because of my camera and darkness. The 24-grid LED set in the dome are way brighter than the map lights, obviously. The map lights light the front seat area about as good as the stock ones did. The cargo area is a festoon bulb set of 6 LEDs, so it's pretty bright. I like the look, but the cool white might take some getting used to for some. My dome was already this color because I did it earlier. License plate light looks good...modern!
I have a 48 Led grid, 5050SMDs, front are tiny 9 grid 1210SMDs, cargo, a 15 grid 5050SMD which fits flush in the area available.
that 48 is killer vampire day light bright!! Everyone complains how bright it is at night when getting out of the car. Tho i wonder how much the 48 drains compared to stock.
Check out my Build thread:
Old 10-08-2010, 12:23 AM   #27
Qmobile
that's right I went there
Qmobile's Avatar
Drives: '08 Blazin' Blue,'10 Dark Red
I wonder how led's would fare in the cluster/center stack controls? one of my knobs is out :( for some odd reason it just went out
Mods: 15" SSC rims, TRD Exhaust, TRD Sway bar, TRD oil filler, TRD rad. cap, TYC tails, Debadged, Painted engine cover, Stock spoiler, Stock mud gaurds, OBX pedals.
suggestions always welcome
Qmobile is offline   Reply With Quote
Old 10-08-2010, 01:06 AM   #28
chrisj
chrisj's Avatar
I thought somebody did that? I thought I remembered seeing it somewhere here. Maybe they were just changing colors.
Old 10-08-2010, 08:29 AM   #29
Qmobile
Qmobile's Avatar
I believe, could be wrong, but I think all that's been done is a color change.
Old 10-13-2010, 12:15 AM   #30
sqcomp
Roadrunner Jr.
sqcomp's Avatar
I just replaced my trunk light, my dome light, and my reverse lights. Thanks for bringing this information to light. Superbrightleds.com is about to make my car all LED...I'm ordering my turn signals and brake lights next week. The fronts will be the week after. Man those LEDs are bright! Good stuff!
― Thomas Paine
Old 10-13-2010, 03:08 AM   #31
Might as well post mine:
(since changed this to two on each side)
Old 10-13-2010, 03:12 AM   #32
I replaced mine in my sedan, there's not a lot of space, so you can only use one smaller LED and a small resistor for each knob.
Old 10-13-2010, 03:15 AM   #33
^ oh, and you'll have to disassemble each knob, pop off the holder holding the bulb in, install the LED in the holder, put the holder back in, plug in the wire harness back into the back of the control, test to see if you have the polarity right (if you do, great, reassemble the control knob, if not, pop the holder back out and flip it so that the polarity is correct). Then you can put everything back. hahahahahahahaha.
When you disassemble each knob, it's a good idea to have the settings all the way to the left or all the way to the right so that you can line up the gears correctly (careful to not lose those either).
Old 10-13-2010, 03:17 AM   #34
Might as well post these too:
LOL!
Old 10-13-2010, 06:48 AM   #35
ross sez
Drives: 08 Yaris 5spd Sedan
How'd you wire the LEDs on the inside of the hood? That looks great!
ross sez is offline   Reply With Quote
Old 10-14-2010, 04:52 AM   #36
For those wondering about my engine bay LED, I used an inline fuse connected to the battery and to a switch. The LED wires were snaked through the hood and down the driveside hinge (you can kinda see it in the pics), and connected to the switch. The LED and the switch were grounded separately.
Here is a pic of the switch and its location:
DIY (08' USDM LB): Interior Light Color Change revnull DIY / Maintenance / Service 37 05-21-2016 12:59 PM
Help!! Where do i find led lights for the interior dome light Pwr_Dori Cosmetic Modifications (Exterior/Interior) 11 07-26-2010 02:53 AM
Interior LED Ricey Problem xbr3akd0wnx Cosmetic Modifications (Exterior/Interior) 10 05-06-2010 08:50 PM
Interior Light LED Conversion nick.dollimount Cosmetic Modifications (Exterior/Interior) 0 04-24-2010 10:48 PM
My ebay fog lights and led interior light pics Julz Photo-Video-Media Gallery 6 09-13-2007 10:41 AM
