Hardwire garage door opener
Anyone on here every done it with their Yaris? I plan on doing it soon, just not sure what I'm going to use as a trigger. Suggestions?
Simple momentary switch connected to where the original switch is i guess would be easiest.
Or be crazy and have it sense your car's approach and door opens automatically.
![]() ![]() ![]() Drives: 2010 Meteorite Metallic LB Join Date: Feb 2010
I did one on my motorcycle using a momentary push button from an alarm.
![]() ![]() ![]() ![]() Drives: 2009 Meteorite Metallic LB MT Join Date: Oct 2008
^ Yes. Thanks for the link
![]() ![]() ![]() Drives: 2009 3dr LB Manual Join Date: Mar 2010
I actually got a HomeLink module from the junkyard, took the buttons and LED out, extended the wires, and put the buttons in a blank by my e-brake. The module is up under the gauges. Works great, plus I can re-program it for anything I need.
Where do I find out more about the Homelink module and how it works?
Are you re-programming that module? |
HomeLink is something found in a lot of vehicles today, integrated into the rear view mirror, the sun visor, the headliner, etc, etc. It can be programmed to any garage door opener as well as remote light controls. The idea originally was that a person could pull into their driveway, hit one button to turn on the front lights, then hit the garage door button. Only the garage door part stuck, as the house lighting wasn't popular.
I attached some pics of one of the modules I got at a junkyard. You can see the buttons in the console. This is the HomeLink logo: This is the removed module: These are the buttons that need to be unsoldered and wires connected for extending it. I also extended the LED which is used for programming: And here is my new opener that I made. It's rubber buttons from something else, with a new circuit board with switches under it. Sorry, the second picture is blurry: Now, this is an easy project if you can solder and have patience! |
Only Happy When it Rains
the big problem with that though is garage door openers have gone to a random billion or trillion+ code rotation, so that only works with older garage door openers now.
Colin Chapman disciple |
I don't know what the new ones are, but I have Lift-Master openers, 2 are brand new, and mine works on them. You're right, you'll have to read the manual first.
| DIY Stealth Garage Door Opener Button | PatrickJohnson | DIY / Maintenance / Service | 38 | 10-08-2010 03:42 PM |
| Penguin Garage Rear Hub Spacers!! | Penguin Garage | Sponsors Classifieds Area | 92 | 09-02-2009 07:16 PM |
| Penguin Garage Rear Hub Spacer Raffle!! | Penguin Garage | General Yaris / Vitz Discussion | 27 | 06-30-2009 02:05 AM |
| ****Kami Speeds 09 Garage Sale/Meet****, up to 60% off everything in stock!!! | SAKU | Southeast | 19 | 06-28-2009 10:28 PM |
| Need help finding a garage remote | Lafiro | In Car Entertainment + Electronics (audio / video / alarm) | 7 | 11-26-2006 11:14 PM |
