#19 |
diaper change in a yaris
Drives: 2009 multimode hatchback 5dr Join Date: Dec 2009
0w-20 wight oill
Hey guys,
I've seen in the owner's manual in my yaris (1.33L 1NR-FE engine) that they also recommend 0-20 weight oil,since 2009 (the year the manual was published). But the dealership's mechanic in Israel told me that this would damage the engine (although the manual specifically recommends it,even over 5w-30 oil). has anyone experienced side effects?bad start up?cranks?anything related to the low viscosity of the oil? and another thing-why has it taken so long (over a year) to approve the 0w-20 oil in the US,while it was authorized in europe and Israel in the toyota manual?
"there is no secret to the balance..you just have to feel the waves.." Heretics of dune. |
#20 |
WCOAST CANADIAN DRIVER!!!
Drives: 2010 Hatch 5DR - AUTO/AC Join Date: Jun 2010
I just took my Yaris in again for its 2nd 0W-20 oil change on October 16, 2010.
And still - there is no written documentation stating that it's recommended - or even approved for the Yaris. I just remember hearing somewhere that synthetic oils are better than fossil fuel oils. So - I'm at a 50-50 - I put about 200-230 KMs a day on my Yaris - and with 0W-20 it seems to run fine - so I'm thinking maybe just switch to reg oil and see what happens? I should mention that I'm not the least bit mechanically inclined so I'm at the mercy of the stealership. |
#21 | |
you put 200-230 KM on your yaris daily?that's 5600 Km approximately in a month! My yaris is only 10900 Km after a year.. anyway, If there is no written documentation or TSB on the subject,I think you should keep up to your owner's manual and stick to synthetic oil only. The reason for synthetic oil is that it's less prone to shear and oxidization under extended perios of time and mileage. what is your manufacturer's recommendation?
#22 | |
![]() ![]() Drives: Yaris sedan Join Date: Jun 2010
Um..You put in 3.3 quarts of oil in your yaris? Although i drive the Yaris sedan, but i think we have the same engine. My owner's manual states 3.7 quarts of oil with the oil filter change and 3.4 without the oil filter change.Also i don't see the point buying a 5 quart jug of oil when our car takes less than 4 quarts of oil. i just buy 4 bottles of oil. |
#23 | |
![]() ![]() ![]() Drives: 2007 Yaris Hatchback Join Date: Jan 2010
#24 |
I'd rather have more oil than less oil(less lubrication)
I don't drive as much as you do. I can barely rack up 3k miles in 6 months, so i change it twice a year, that extra quart of oil might get contaminated somehow. I really like the placement of the oil filter in our yaris, there are no wires or reserviors around it:) it's so easy to wrap it around with an oil filter wrench. |
| Yaris Oil Change DIY | rningonfumes | DIY / Maintenance / Service | 91 | 01-11-2019 07:18 PM |
| DIY: CHANGE MANUAL TRANNY OIL | ttufrosty | DIY / Maintenance / Service | 157 | 09-07-2018 01:43 PM |
| A Mystery Oi'll Say! | Yar Is Word | Fuel Economy Forum | 16 | 05-11-2013 04:22 AM |
| Synth Blend Oils | scape | DIY / Maintenance / Service | 7 | 07-12-2009 01:55 PM |
| Motor oil debate - interesting info but a long read. | mikeukrainetz | General Yaris / Vitz Discussion | 6 | 12-10-2006 08:16 PM |
