Old 10-24-2010, 11:15 AM   #19
yaris2007_22
Drives: Toyota Yaris 2007
How can I access the engine drain block plug? Under the vehicle or just under the hood? What does it look like? Thanks!
yaris2007_22 is offline   Reply With Quote
Old 10-24-2010, 11:23 AM   #20
1stToyota
1stToyota's Avatar
From underneath, backside of block, in the middle, above oil pan gasket surface ...it's the only thing that looks anything like a drain port.
1997 Lincoln Town Car - SOLD
2008 Scion xD
(w/ automatic) - SOLD
2008 Yaris HB - SOLD
Old 10-24-2010, 03:50 PM   #21
yaris2007_22
Thanks a lot! That work out great, however I dont think it was worth the time and effort to drain coolant of the engine drain block, it only spitted out 1/4 cup. That drain block was a tight space. I got a half bucket of coolant of the radiator drain cock, which I will just only do next time.
Old 10-24-2010, 11:09 PM   #22
1stToyota
1stToyota's Avatar
I've never drained mine but 1/4 cup sure doesn't sound right...was the cap removed?
2008 Scion xD
Old 10-25-2010, 10:34 AM   #23
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
^ no, that sounds about right. You're only draining the remnant from the back of the block because of the rearward tilt of the motor.
Old 10-25-2010, 12:42 PM   #24
1stToyota
1stToyota's Avatar
Really? Wow. If so, sounds like the most worthless drain plug location ever designed.
2008 Scion xD
Old 10-25-2010, 02:31 PM   #25
Bluevitz-rs
Well, otherwise how are you going to get that last little bit out?
Old 10-25-2010, 02:40 PM   #26
1stToyota
1stToyota's Avatar
1/4 of a cup?
2008 Scion xD
Old 10-26-2010, 11:36 AM   #27
jstantherprsn
Drives: 01 Toyota Echo
just got the repair manual, I'm going to look up the process for draining. hopefully there are bleeders.
jstantherprsn is offline   Reply With Quote
Water Pump issue, after taking in for Recall GeneralDon7 General Yaris / Vitz Discussion 34 05-27-2012 09:04 PM
Yaris Fuel Pump HTM Yaris General Yaris / Vitz Discussion 12 03-22-2012 04:34 AM
Water Pump leaks and then stops CB900F2 DIY / Maintenance / Service 30 05-09-2011 10:14 AM
Hmm my water pump failed again!!!! Could it be the pulley?!?! YarisSedan Performance Modifications 64 10-05-2009 10:32 PM
