Old 10-27-2010, 10:07 PM   #271
Dragracer
Yaris Noobie
Dragracer's Avatar
Drives: 2010 Yaris 3 Door
Fixed! I had to turn off the GPS receiver, and then allow the radio to search for it. It was found, and is working fine now!
Calling an illegal immigrant an undocumented worker, is like calling the corner drug dealer an unlicensed Pharmacist.
Dragracer is offline   Reply With Quote
Old 10-29-2010, 02:48 PM   #272
footcookie
Drives: '07 Black Pearl
$295
http://www.ipmart.com/main/product/C...hp?prod=133796
footcookie is offline   Reply With Quote
Old 10-29-2010, 04:49 PM   #273
Eatoman
Eatoman's Avatar
Drives: '07 Yaris 5dr HB
Originally Posted by footcookie View Post
Not bad....BUT, I did manage to find this one at $379 US with FREE SHIPPING AND a reverse camera included!
http://www.compucn.com/Original-OEM-...x-Corolla.html
Eatoman is offline   Reply With Quote
Old 10-29-2010, 05:37 PM   #274
footcookie
Missed that one, but , I probably wouldn't have used the back-up camera anyway. Would have been nice to have to resell though.
Old 10-30-2010, 10:57 PM   #275
mojokin
Drives: 2010 Toyota Yaris
I just noticed that this will not fit the space without modifications for the 2010 model(Philippines). I need to replace the center panel of the dash board and it's gonna cost me around $200 more.
mojokin is offline   Reply With Quote
Old 11-02-2010, 03:05 AM   #276
amanda_84
Drives: 2010 Toyota Yaris YR
Send a message via MSN to amanda_84
Originally Posted by Dragracer View Post
I mounted the GPS antenna on the black plastic filler under the wipers. I already had the XM radio antenna mounted there. The GPS antenna is similar in size and shape, and both blend in very well. Photos are below.
Here's where my XM antenna is mounted.
Here's the GPS antenna mounted there as well.
Hi, i'm wondering how you mounted the GPS antennae under the wipers as id really like to do this but I've not really don't much in tinkering to cars! Did you have to drill a hole or 'grommet' somewhere to thread it through?? (I don't even really know what a grommet is!).
Also...does any one know if the pre-loaded GPS software is upgradeable? OP said he put different GPS maps on a bigger card - how do you get the maps?
cheers for any help guys,
Amanda
P.s. I'm about to go install the HD now yippeee
amanda_84 is offline   Reply With Quote
Old 11-02-2010, 06:47 AM   #277
Dragracer
Yaris Noobie
Dragracer's Avatar
I routed the wiring to the right door, I went behind the glove box, and the right side of the dash will flex enough to get the connector through. I pulled the rubber door seal away from the body, and ran the wiring between it and the body, then used my hand to reinstall the weatherstrip. I attached the antenna lead to the washer hose with wire ties. The left side of the black plastic trim just pops in place. It's easy to remove, and install the antenna.
Old 11-02-2010, 09:12 PM   #278
amanda_84
Installed and running. I had the same problem as the others with the GPS not finding the right file. But cleared it up thanks to those who posted their same issue here.
It really was so so simple to install, although we originally where confused as to what cables were what as nothing had labels and the instructions where only on the software not the connection. But by matching size for size we figured it out! And i scratched part of the dash plastics getting it in and screwing about undoing the orignal deck...grrr.
My only problem now if that I only have the SRC light that is red. And the two either side of the DVD slot. No other lights work and I can't change the colours through the settings....anyone else had this or would know what electrical connection might be loose for me to plug back in??
Old 11-03-2010, 04:32 AM   #279
daveprue
My Pride & Joy...
daveprue's Avatar
Drives: 2010 Yaris 5 Door LB
To set the colors of the other LEDs, go to the "SRC" screen and touch the small icon third from the right on the bottom. Pressing it again will change the colors. Note that the SRC led is always red.
Dave
daveprue is offline   Reply With Quote
Old 11-03-2010, 09:53 AM   #280
footcookie
Got mine yesterday. Installed it in about 15 minutes. Sound is better than the stock unit. Haven't spent much time with it yet, maybe 45 minutes. The GPS Nav is fine, everything works fine, not sure why the TP kept flashing on the way to work this AM. It will take awhile to get familiar with it, but after only 45 minutes, I'm pretty impressed. It is very clean and looks factory when installed.
Old 11-04-2010, 12:33 AM   #281
amanda_84
thanks daveprue, I also realised that i needed to have the car lights ON and then the other lights on the unit light up. HA! what a stupid thing on my part. But thanks for the info.
Old 11-04-2010, 09:52 AM   #282
toy_toronto
always toyin'
toy_toronto's Avatar
Drives: 2010 5-Dr
I'm very glad to hear that you are all fairly satisfied with your head units.
-toy
Old 11-05-2010, 09:34 PM   #283
Darwin84020
Drives: 2007 Yaris, Hatchback
Hello,
OK, I'm hooked and ready to buy (money in hand and pay day over!). However I want a HU that looks like the OP (toy's, ect) and not the one with the radio dials midway down on each side, I think Dragracer got this one.
Can someone point me to the right one to get please, don't want to get scammed out 400 big ones.
The one I was thing is linked here off of DHgate.com site -
http://www.dhgate.com/custom-car-dvd...9b8026764.html
Thanks
Darwin
Darwin84020 is offline   Reply With Quote
Old 11-05-2010, 11:43 PM   #284
daveprue
My Pride & Joy...
daveprue's Avatar
Originally Posted by Darwin84020 View Post
Hello,
Thanks
Darwin
Looks to be the unit that you want. Price is about right also about 400-420 with shipping. I bought the one off of eBay, simply because I have no experience with DHGate, and I trust the eBay Buyer Protection. The one I just located on eBay is http://cgi.ebay.com/Car-DVD-Player-G...item4aa5961ad5 but looks to be slightly higher with shipping.
Anyway, good luck!
Dave
Old 11-09-2010, 01:10 PM   #285
rognewton
welshdodger
rognewton's Avatar
Drives: toyoto yaris
Multimedia Player
Hi to you all at Toyoto yaris forum
This is my second time i tried to upload this info
the first time seems to dissappered
I have bought a Multimedia Player like the one's you all shown
I read the 16 pages on how to replace a works radio with the Multimedia Player, and with your great pic's i can see how to remove the unit and replace it with mine.
The question i have is there,s no pic's of the back of the radio comming out
with all the plugs
On my Multimedia Player unit i have a load of female Phono plugs for speakers,
Is there a load of male Phono plugs ready on the yaris for me to plug into,
or do i use them at all.
i going to uplload pic's of my Multimedia Player unit
any help with please
thanks
rognewton
rognewton is offline   Reply With Quote
Old 11-09-2010, 01:33 PM   #286
rognewton
welshdodger
rognewton's Avatar
Multimedia Player
Hello all at toyota yaris forums
I cant work out how to add Pic,s to my Post
i have managed to add Pic' to attachments
i dont know this will work
if any one can help
thanks
rognewton
Old 11-09-2010, 03:18 PM   #287
Your standard speaker connections are made through the two wiring harnesses that are wrapped in foam. These will (should) just plug straight into the existing harness behind your dash.
All the other 'stuff' is for external devices such as DVD screens, backup cameras, iPods, etc. The grey and black extra speaker wires are probably of no concern to you at this time.
Hope that helps you out some.
Old 11-09-2010, 04:38 PM   #288
rognewton
welshdodger
rognewton's Avatar
Thanks WeeYari,
I been puting off fiting this unit, just in case i messed up
thanks for your advice
rognewton
ACRONYM thread Shroomster Off-topic / Other Cars / Everything else Discussions 45 02-15-2025 10:30 PM
Used Kenwood 7037 Double Din Touch Screen +10 Disc Changer ! micquek Items for Sale by private party 0 12-31-2009 08:31 AM
Getting ready to get a DOUBLE DIN touch screen player, NEED INPUT! Syroyizhka General Yaris / Vitz Discussion 12 04-08-2009 10:26 PM
Decent eBay deal on harness and double DIN kit Sodium Duck In Car Entertainment + Electronics (audio / video / alarm) 6 03-23-2009 12:04 AM
