#469 |
145hp
![]() I guess most of the power is locked up in the head
#470 |
![]() ![]() ![]() Drives: yaris1.33 Join Date: Jul 2010
not bad result for the atmospheric engine ;)
#471 |
^ balanced and blueprinted also, not all in the head work. An inspiring result for an N/A build on that motor.
#472 |
and I'm sure if they weren't restricted to certain stock parts it would be even higher. TB, intake manifold... ect.
#473 | |
![]() ![]() ![]() ![]() ![]() Drives: 2015 H Production Yaris Join Date: Oct 2009
The engine is not balanced and blueprinted, 100% OE Toyota bottom end, never touched. Also keep in mind, as I said when I posted the old dyno sheet, this is from a Dynapak, these are not at the wheels numbers. While I think we made great power for our first crack at this engine, it is not a 145hp at the wheels monster. In reality it should be down a hp or two from that, since we had to pull what was left of the aluminum pulleys off.
2005-2008 SCCA Solo BS National Champion 2017-2018 SCCA H Prod National Champion
#474 |
hmm, Ok I sit corrected.
isn't the old dyno before cams and management change, though?
#475 |
145hp@7252rpm
moar redline?
#476 |
oh, i see....peak power rpm fudged by toyota?
#477 | |
Bolt-ons and the Camcon will get you 90% of what we made. For the rest you need to get past the rev limiter, the AEM got us that, and better control of VVT-i, this is where the next chunk of power came from. With our Level 2 prep limits only allowing us max .390 cam lift, and port matching 1" in, we did not make a lot of power on the head. There is still a lot left in there, but as long was we race the car in H Prod we can't go further into the head.
#478 |
No, that was our old dyno sheet. Before the AEM, cams and port work. That was bolt-ons and the Camcon.
#479 |
i wouldnt mind seeing the newer dyno sheet if you have access to it...
#480 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '08 Yaris Join Date: Oct 2008
What all bolt-ons did you have on? Is there list somewhere?
#481 |
![]() ![]() ![]() ![]() ![]() Drives: . Join Date: Apr 2007
#482 |
All of the parts are listed in the story in SportsCar, there is a link to download a PDF of it in this thread.
In a nutshell - the power stuff: AEM EMS series 2 - you need the ability to control the VVT-i/fuel/ign to make all the other parts work to full potential. Without a tune you will get minimal gains from the rest. This car was originally tuned for economy and reliability, there is a lot of power that can be unlocked with a proper tune. Okada coils K&N intake DC header/Coast Fab muffler/no cat SPEC aluminum flywheel NST pulleys - these were on when we did the dyno runs, and for most of the season. Once we started running 7300+rpm on the track the crank pulley failed, so we went back to stock.
#483 |
Awesome, thanks Jason. Your car rocks. Finally some motivation to try and pull some N/A power from a 1NZFE.
#484 |
Modded Moderator
Drives: 07 Toyota Yaris, 71 Galaxie Join Date: Mar 2007
I love this thread.
#485 | |
also, im assuming that the NST pulleys are a bad idea for running past the stock rev limiter then? this worries me cuz i just installed these guys and i autocross. sometimes on a quick straight i will stay in second and let the rev limiter bounce if there is a quick turn not to far but would be losing time if i go to third. |
#486 |
If you're on your rev limiter, you are at around 6250. You can't run past the stock rev limiter.
Jason's pulley broke in two, completely destroyed. Pretty sure a pic got posted.
| Hood Stay (lift) Instal | 1NZYaris1 | DIY / Maintenance / Service | 31 | 09-22-2016 07:56 PM |
| The opposite sex can't stay away with ssk | POORSHA | DIY / Maintenance / Service | 20 | 08-19-2009 10:41 AM |
| eTiMaGo Stay safe | Bob_VT | Off-topic / Other Cars / Everything else Discussions | 20 | 12-02-2008 05:31 PM |
| Tuned a DBW Toyota yesterday | Turbo&Auto | Performance Modifications | 17 | 08-17-2007 12:04 AM |
| why am I always here?! wtf...i cant stay away.. | Blenjar | Off-topic / Other Cars / Everything else Discussions | 5 | 02-26-2007 10:51 AM |
