Old 11-04-2010, 01:49 PM   #1
weapon5
Drives: VITZ
Need a little wiring help?
Hey guys I am trying to install a bulldog remote starter rs1100 system and i am having an issue with it.
issue when i press the button it will crank than dies?
any clue.
I was thinking my wiring off since i found a thread on here and also using the bulldog wire diagram and they are both way different not even close.
so what do you guys think it is. (yes i have the bypass module) maybe someone on here have the same setup and made it work successfully. :D thanks for the reply.
weapon5 is offline   Reply With Quote
Old 11-04-2010, 04:16 PM   #2
Palmer812
Drives: 2010 Meteorite Metallic LB
I don't know anything about Bulldog but there is one thing you can try. Put your key in the ignition but don't turn it on and then remote start it. That will tell you if your bypass is working or not. If the car starts and stays running the bypass isn't working. If it still shuts off something else is wrong. I don't know if the Bulldog has a tach signal or if it is voltage sensing.
Palmer812 is offline   Reply With Quote
Old 11-04-2010, 04:21 PM   #3
If it starts and then dies, typically that means that your tach wire is not correct. If it cranks and doesn't start, then you are dealing with a transponder key bypass issue.
Old 11-12-2010, 03:20 AM   #4
weapon5
Drives: VITZ
crap i already ripped it apart lol getting a different remote starter now lol oh well. :D
Installing Trailer Light Harness vandallen DIY / Maintenance / Service 7 06-10-2024 10:06 AM
Connecting wiring to small trailer charles nelson DIY / Maintenance / Service 8 04-24-2012 05:39 PM
Tapping into the aux wiring stanger454 In Car Entertainment + Electronics (audio / video / alarm) 4 09-04-2010 09:08 PM
Wiring Pictures MitchEvious In Car Entertainment + Electronics (audio / video / alarm) 2 12-28-2009 11:43 AM
Wiring color code for 2008 LB? charles nelson DIY / Maintenance / Service 0 04-25-2009 03:56 PM
