#739 | |
![]() Mess or not, I'm having fun! sanding and mixing. Remember that some of the best ideas come from mistakes. Bad or wrong I'm getting every body in the same boat, and for other newbies like me will learn how not to do it! I did sand the spheres with 80-grit! before applying glazing putty This glazing putty gets pretty hard and it's not easy to sand, I can't imagine "Bondo" (I have never worked with Bondo) I like the lamp nipples too, they are strong and useful. Thanks. Now to get them finished mmm.... that's going to take a while, you know me I'm very slow BTW... I would like to finish the spheres with FLOCK, does any body know how to do it or where to buy the materials? or a DIY These photos show my progress, after 20 minutes of sanding on each sphere and some test fit with the HL-70's and at the end next to a 6.5" Premier component, Huuug the HL-70 look so tiny, just for reference the spheres are 5" diameter. I finished the night work with a second layer of... you know that glazing putty more sanding over the weekend. ![]() ![]() ![]() ![]() ![]() D. |
#740 | |
But no tweeters here "yet" The HL-70 are Mid-rage drivers; a second set of spheres will host the tweeters! diffractions-diffractions-diffractions ![]() ![]() ![]() LINK to diffractions information . Thanks again D.
#741 | |
![]() Please expand on this, explain? ![]() " I would have made the sphere's aimable on the X and Y axis" I thought about it but the anchor would have been too big, and I did what you did testing the L4's aiming in different ways until they sound better, I tried "off axis" up and down I spent like 2 month moving the Mids (HL-70) around until I found the sweet spot, I will do the same for tweeters, like I wrote above tweeters get their spheres too! and these may get a camera pivot at the beginning and then after finding the right aiming will place fixed, all depend on how my new L1v2 will respond inside my car. Yes I did wrote L1v2! "PLENTY of sanding going on" I know!!! it scares me, but I'm working on it. ![]() ![]() ![]() "That's why my finished pillars look so good"...A+D. |
#742 |
![]() ![]() ![]() ![]() Drives: Yaris Sedan 2009 Join Date: Sep 2010
I can't wait to see this done.....maybe i could do this with my tweeter in my car :O
They lookso great with those little nertz ..im a kind of jaleous !!
Interior:ALL red, black roof Exterior:RTX scorpion painted GOLD, side and rear visor, oem spoiler, MI mesh grill, Hella supertone horn, RS badge, Vios badge, CF pillar, Led mirror cover, fog light HID 3000k, Projector retrofit HID 8000K Performance :MI CrankPulley, Tein springs, UR and TRD bar, TURBO IN PROGRESS Audio : Pionner DEH-80PRS, HAT L1V2, PowerBass 1100.5X 5 channel amp
#743 |
Roadrunner Jr.
We'll hear how they sound when you get them fired up pertaining to the stage width issue.
Also, those mounting holes for the speakers, you can use thread-serts in there as well so you don't chew up the baffle when you take the speakers in and out.
“To argue with a person who has renounced the use of reason is like administering medicine to the dead.” ― Thomas Paine |
#744 | |
I found this in a Robb Report magazine: ![]() The Mid-range drivers HL-70 from Hertz are beautiful made in Italy D. |
#745 | |
STAGE WIDTH : Stage Width refers to the distance between the left and right boundaries of the sound stage. Good systems will create a wide sound stage. Excellent sound systems will have sound stages that appear to surpass the physical boundaries of the vehicle interior. How the spheres would subtract stage width? in one of the threads a few weeks ago, you told me: "go for the spheres!" I realize that the distance between drivers it's smaller if using the spheres, that is why I wanted to have them in front of the "sail panels" remember my first attempt; because I wanted the drivers as far away from each other, even I asked what was better if having them further from listener or a little closer but farther apart from each driver... for convenience I decided to go this way, I like the look but also keeping them separated from the A-pillars structure keeping me away from trouble that the joins between the baffle and the A-pillar would "Crack". I see a lot of Team Hybrids and others installations have the drivers aiming very similar to what I wil have, do they have the same stage width issues? Here a few installations! ![]() ![]() ![]() ![]() ![]() ![]() ![]() I agree 100% I'm going to use thread-serts to hold the drivers. "very clever" Thanks D.
#746 | |
Well If your gonna use those speakers, might as well get these amps to push them.....the best you can get....wanna know the price?lol Last edited by sickpuppy1; 11-07-2010 at 01:05 AM. |
#747 |
hmmmmmm that gives us much idea thanks Derick !!!
#748 |
I ain't even mad
WOW looks great man, how did you get the guts to see your car in that condition lol
#749 | |
she asked me, if I was going to be able to put it back together, I just smile at her. Thanks D. |
#750 |
Roadrunner Jr.
The 1st and 4th pictures are of Jim Becker's old and newer setups. The answer to your question of stage width will be answered by the front end setup track. Run that track through and listen to see if the sound extends beyond the boundaries of the pillars.
You also notice that those pods are MASSIVE! You guys thought mine were big. My pillars are made to highlight imaging and soundstage accuracy. As for construction details, I understand what and why you're doing it. I'm on your side. I may have done this approach a little differently, but it's not my setup. Make it happen, don't think I'm trying to shoot you down.
#751 | |
It's a learning process and it's just like raising my hand when I don't understand something but besides telling it would have an issue I would like to know why? so we all can learn from the Pros! like you! I'm going to try and come up with a solution to compensate the stage width by putting the tweeters in front of the sail panels so they are as far apart from each other to create a wider stage!, we'll see... for now I'm grounded with a cold and a terrible toothache!
#752 | |
Just a Herbicidal maniac.
Drives: 2008 Yaris S Sedan Flint Mica Join Date: Oct 2008
2008 Toyota Yaris (Vios) 'S' sedan, Flint Mica, dropped on TRD springs, TRD anti-sway bar. Tinted rear windows. Lenso Samurai SC02 hyper black 17" x 7" rims, wrapped in 205x40x17 Federal ss595's. Color matched eyelids. Vios badge. Body color trunk trim (was chrome). Lamin-X tint on rear tails. Custom center exit exhaust. Tanabe front strut tower brace. |
#753 |
#754 |
A little bit more "sanding"... Getting there! the never ending story...
Should buy some primer and thread serts tomorrow ![]() I feel a little better now. Should go to sleep zzzzzD.
#755 |
Roadrunner Jr.
now...put on more and sand again. I see ridges...
*tough love*
#756 |
| sound deadening: sq footage amount for 3dr | goku87 | In Car Entertainment + Electronics (audio / video / alarm) | 29 | 11-14-2013 12:37 PM |
| 2007 Yaris S Sound Deadening | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 70 | 12-13-2010 07:40 PM |
| Sound deadening | 06vitzRS | General Yaris / Vitz Discussion | 10 | 05-05-2010 01:51 PM |
| Sedan Door Panel Deadening | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 42 | 06-01-2009 02:47 PM |
