Old 02-06-2007, 03:08 PM   #19
Doc Zaius
Lurker supreme!
Doc Zaius's Avatar
Drives: old and boosted!
Hey rw... just saw the pics in your garage... look good! I think I prefer the 45 profile tire with the 16's than the 50 profile. Just my preference. Now you have to get the car lowered!!
2006 Red Blitzed RS 5-door
Old 02-06-2007, 03:16 PM   #20
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
Agreed, it looks great!
PetersRedYaris is offline   Reply With Quote
Old 02-06-2007, 05:35 PM   #21
rwseattle
Rwseattle
rwseattle's Avatar
Drives: 2007 Toyota Yaris (BASE)
Question Springs
Thanks. I agree on the lowering springs but, I'm not sure about the type of spring TRD or Tanabe DF210.
TRD 1.0 f and r (factory warranty)
DF 210 Tanabe front 1.6 and rear 1.8
NF 210 Tanabe front 1.0 and rear 1.3 (I think these will work best)
I Like a more level look. The back needs to come down. What do you guys think?
Thanks
Ron
rwseattle is offline   Reply With Quote
Old 02-06-2007, 05:48 PM   #22
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
I recommend Springtech. 1.7 inch drop all around. The DFs are too low in the rear for my taste. Check out my garage pics if you like.
Old 02-06-2007, 07:40 PM   #23
rwseattle
Rwseattle
rwseattle's Avatar
Yes, your car looks great with the Springtech 1.7. You do have the 205/50/16 and my car has the 205/45/16. I'm going towards the Tanabe front 1.0 rear 1.3 or your Springtech 1.7 in lowering springs. How's the ride with the Springtech springs? Thanks for your feedback.
Old 02-07-2007, 12:58 AM   #24
largeorangefont
Break'em off some.
Thanks! Your car is gonna look great when you lower it. I guess we both have similar tastes.
For me it was between the TRD springs and the Springtech. The TRDs just don't look quite low enough on cars with 15s or 16s. They look alot better on cars with 17s or 18s.
I was pleasantly suprised with the ride after I installed the springs. The car rides great. My tires slightly rub the inner fenderwells at high speed on large bumps. You probably wont have that issue because your 45 series tires are a little shorter.
I will be installing the TRD shocks/struts soon and that will solve my slight rubbing issue.
I got my springs on Ebay for $130. I was local so I picked them up.
Old 02-07-2007, 01:12 AM   #25
PetersRedYaris
Mine has the NF210's. If you check my garage at least you'll get a visual. Measured drop was just as advertised. They ride great (much more firm than stock but not at all harsh), but, they look almost like a factory sport suspension. I think a little more drop looks better but obviously it wll be much stiffer. Mines a daily driver (100 miles per day).
Old 02-07-2007, 01:20 AM   #26
Doc Zaius
Lurker supreme!
Doc Zaius's Avatar
Interesting...!! I have the TRD springs... good to know! Thanks.
Old 02-07-2007, 12:01 PM   #27
largeorangefont
Break'em off some.
Thats just my opinion from hours of looking at pictures on here.
Old 02-07-2007, 02:45 PM   #28
rwseattle
Rwseattle
rwseattle's Avatar
Did you install the spring or had a local tires center help you? I'm thinking about installing the spring with the DIY info. I will keep you posted.
Old 02-07-2007, 04:19 PM   #29
largeorangefont
Break'em off some.
Its easy to do yourself. The diy info was helpful, but I saw no need to remove all the cowl stuff and the wipers in the front. Just make sure you have an offset 17mm box end and a 6 mm allen key and you will be good to go in the front. The back is very easy.
Air tools will help, removing and installing the strut shaft nut to remove the spring, but aren't necessary.
Old 02-07-2007, 04:42 PM   #30
rwseattle
Rwseattle
rwseattle's Avatar
Wink
That's great. I will order the springs soon and install them. I will post pix right after the installation. Thank you for your feedback.
tanabe nf210 vs. TRD lowering springs?? static808 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 37 01-24-2012 12:00 AM
Lowering Springs - Questions ~ jaspie Wheels, Tires and Suspension Forum sponsored by The Tire Rack 16 01-10-2007 09:21 AM
TRD lowering springs' and/or shocks' Ride Quality?? static808 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 28 08-29-2006 01:42 PM
Will putting new lowering springs damage original shock absorbers in the long run? Joel Leong Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 06-07-2006 09:30 AM
Factory Lowering Springs + MAX Wheels? What are the options? bigsky2 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 05-24-2006 09:10 PM
