Old 11-22-2010, 11:21 PM   #1
ezhacker1
ezhacker1's Avatar
Drives: Decepticon - Ravage
Unforntunate events led to CV boot torn
The unfornatuate events that led to me finding out my CV boot was utterly ripped all the way around this afternoon.
1. Bottom of Coilover adjuster thingy may not have been tighten all the way
2. A rainy night
3. Looked down from the road for a second
4. Hitting a big pothole at 40 mph straight on Friday night
Basically the bottom of the coilover adjuster thingy I assume got jarred loose from the pothole then ongoing vibrations from driving loosen it further and finally sat ontop of the shaft basically be a lathe and started chewing up the coilover piece.
Let this be a lesson to everyone... i now have zipties preventing the other side from coming dropping loose, at the very lease it will vibrate loose but not continue to loosen.
Now i have to wait / drive a 91 Corolla Wagon till the boot to arrive from TRD Sparks, I figure go OEM.
I HOPE this all happened friday night, theres no sound from turning after i fixed the coilover thing.
Check out my Build thread:
Old 11-23-2010, 12:04 AM   #2
tomato
tomato's Avatar
Nasty :(
Good luck with the repairs!
Old 11-23-2010, 12:15 AM   #3
ezhacker1
ezhacker1's Avatar
Im glad i caught it early, tho i cant know for sure i did catch it early, it is most likely started with the pothole on friday.
Any tips for repairs? I know how a PITA it is to just install the boot...labor intensive
Old 11-23-2010, 12:55 AM   #4
MadMax
MadMax's Avatar
I had the same thing happen when I hit an armadillo in Arkansas in 1985 with my year-old Honda Accord hatchback...
Good luck with the repair!
Cheers! M2
Old 11-23-2010, 06:51 AM   #5
There are aftermarket "repair" boots that glue together and don't require pulling the axle to install, but I've heard mixed reviews on the longevity of them. I would pull the axle, completely degrease the joint (to remove any contaminants that got in with the ripped boot), re-grease, and replace the boot. Pulling an axle is not that bad, other than breaking the axle nut loose. You need a 30mm socket for the axle nut and a tool to "un-dent" the axle nut to allow it be rotated. It has a dent that acts as a locking mechanism.
Old 11-23-2010, 05:26 PM   #6
ezhacker1
ezhacker1's Avatar
im gonna purchase an OEM one from local dealership, and take it to my mechanic buddy to fix it for $60 plus $30+tax for the boot kit. I dont trust myself to do something like this. I read up on split boots, i dont trust those either.
Ironically i had thought the pothole destroyed my shock seeing all that grease, but it wasnt pink no way it got all dark that fast.
DIY LED Strip under the door panel charleschia1986 DIY / Maintenance / Service 19 11-05-2011 07:49 PM
Interior LED Ricey Problem xbr3akd0wnx Cosmetic Modifications (Exterior/Interior) 10 05-06-2010 08:50 PM
Shift Boot ... revisited bigsky2 Cosmetic Modifications (Exterior/Interior) 35 04-19-2007 07:04 AM
