Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Second Generation Toyota Yaris Main Rooms > Regional Forums > Middle East
Old 11-29-2010, 07:18 AM   #37
markylicious
markylicious's Avatar
Drives: 2010 Yaris Sedan "Abyss"
Originally Posted by xtremist View Post
wahaha...sana inipit mo nlng kaysa magasgasan auto mo...hahaha...malalim b? kng d nman, touch up mo nlng nung paint na kasama sa yaris mo then i polish mo, ng kaunti, after that iwax mo pra makintab.
kita tlga ung gasgas.. halos kasing lalim ng ulo ng ballpen asar na asar nga ako dun sa indonesian. ok sana kung nakasandal siya dun sa tubo kasi malalaman ko na may nakaharang eh nakatayo lang ung gago
markylicious is offline   Reply With Quote
Old 11-29-2010, 07:20 AM   #38
xtremist
xtremist's Avatar
Drives: yaris Y 2010 A.K.A. "sky"
malalim nga, alin nga ulit nagasgas, ung fender b o sa bumper? kpag sa bumper kc at labas ung itim, d na kaya ng touch paint, kpag sa metal nman at labas na ung galvanized na itsura, d ndin kyanin eh...
Ciao !!!
Yaris X: The Largest Most Organized Pinoy Yaris Owners Group In The Middle East (Eastern Region Chapter)
Disclaimer: Not Connected to Toyota A.Lathif Jameel ME In Any Way
xtremist is offline   Reply With Quote
Old 11-29-2010, 07:23 AM   #39
markylicious
ung passenger side na pinto sa likod.. kapantay ng handle
Old 11-29-2010, 07:30 AM   #40
xtremist
xtremist's Avatar
ouch...kitang kita nga yun...try mo muna itouch up, check mo result if maganda
Ciao !!!
Old 11-29-2010, 07:42 AM   #41
markylicious
d ko alam kung panu lagyan sabi skn karayum daw gamitin ko? eh ayaw kumapit nung pintura sa karayum
Old 11-29-2010, 07:44 AM   #42
xtremist
xtremist's Avatar
try mo pare toothpic, basta ung part lng na may gasgas lagyan mo, mabilis matuyo yun, haluin mo muna.
Ciao !!!
Old 11-29-2010, 08:04 AM   #43
markylicious
na try ko nrin toothpick same resulta.. pag iginuhit ko na sa gas2x walang nangyayari plano ko nga bumili nlng ng water color.. kasi ung brush nun eh manipis? sa tingin nyo sir?
Old 11-29-2010, 08:11 AM   #44
jonimac
jonimac's Avatar
Drives: Yaris Sedan 2010
Send a message via Yahoo to jonimac
Yung sa Nail Polish try mo bro, KOKURYU yung brand!
jonimac is offline   Reply With Quote
Old 11-29-2010, 08:12 AM   #45
xtremist
xtremist's Avatar
ginamit ko yan noon (toothpick) dip k sya maiigitpos ung prang patak ang pahid ko, dahan dahan, pero gumamit din me nung brush na pinaglumaan sa make up, ok din, talasan mo lng dulo, make sure haluin mo mabuti paint kc ung sa ibabaw madulas prang oil.
Ciao !!!
Old 11-29-2010, 08:23 AM   #46
markylicious
cge2x gawin ko yan salamat!
Old 11-30-2010, 05:55 AM   #47
rye7jen
rye7jen's Avatar
Drives: 2nz-fe '10
@mark, i think we have the same problem. Halos same tayo ng part kung saan yung gasgas kaya lang kasama pati yung right front passenger side door ko. Medyo malalim din yung gasgas pero puti lang lumabas,. Na-try na namin nila Joni gumamit ng rubbing compound ba yun Joni? Kaso no luck. Inform mo kami kung magawan mo ng remedyo yan ha. Buti pa kayo may touch-up paint na kasama Yaris niyo.
rye7jen is offline   Reply With Quote
Old 11-30-2010, 06:02 AM   #48
markylicious
sige sir inform kita kung ma reremedyohan ng touch up paint. pero sa tingin ko makikita prin ung mark ng gasgas nag tanong2x ako sa mga paint shop kugn magkano kung sila titira, nasa 120 sr below daw
Old 11-30-2010, 06:23 AM   #49
xtremist
xtremist's Avatar
pre, mahal nga kng sa paintshop kc buo nila pipinturahan, kng d nman gaano kita, leave it nlng muna sa touch up paint, try mo nman post pic ng makita ng ibang kayaris, baka makapag suggest din cla.
Ciao !!!
Old 11-30-2010, 06:28 AM   #50
markylicious
cge.. kunan ko pic tapos post ko agad d2 bukas.. plano ko bumili ng maliit na brush para gamitin instead if toothpick
Old 11-30-2010, 07:54 AM   #51
ricepower
ricepower's Avatar
Drives: Yaris Y Sedan
Send a message via MSN to ricepower Send a message via Yahoo to ricepower
www.paintscratch.com
ricepower is offline   Reply With Quote
Old 11-30-2010, 08:00 AM   #52
markylicious
If you get paint on your skin, remove with paint thinner and wash thoroughly with soap and water.
Do not try to use the paint pen on areas larger than a pencil eraser. Larger areas must be sprayed.
Paint can easily leak out of the paint pen if you do not use it correctly!
Do not try to brush areas larger than a dime. Larger areas must be sprayed.
Use an approved automotive paint respirator and WEAR safety goggles and gloves when handling automotive paint to protect your eyes and skin!! Please read the information below for best results.
When spraying, always test for paint compatibility. Paint an inconspicuous part of the vehicle, let dry and see if there is any reaction.
Do not spray our paint over enamel paint that is less than two years old.
Do not spray primer, paint or clearcoat in direct sunlight!
First time? Did you know you can completely remove any new paint with automotive lacquer thinner and start over without damaging the original finish?
Make sure you use SEM Adhesion Promoter if you are spraying a non-metal surface. Failure to do so will result in the paint peeling off within a few months!
Old 12-01-2010, 02:18 AM   #53
markylicious
nailagay ko na sa albums ko ung pics ng gas2x... http://www.yarisworld.com/forums/album.php?albumid=574
Old 12-01-2010, 03:35 AM   #54
jonimac
jonimac's Avatar
Bro saw d pix, medyo malalim nga ito at mahaba. If ever man makuha sa touch paint, halata mo pa rin. Your call bro...
