![]() Drives: Toyota Vitz 2004 Join Date: Dec 2010
Problem with my car
Hell guys!
I don't know whether it's the right section or not but i need some help about this annoying problem. I've Toyota Vitz/Yaris 2004 (auto) The problem i faced few days back is that the check engine light went totally off. When ignition was turned on, there was no check engine light. Then the problem started that in the morning morning it took too many self starters to start. I had to mess for about 10 minutes to get it started. Now this problem has gone worse. Could anyone please suggest some solutions ?? Thanks |
I would start by connecting it to a OBDII code reader to see if there are any stored DTCs. If the problem is with the ECM, it either won't respond to the code reader, or will report an error with the drive circuit for the indicator light. It is also entirely possible that the LED or bulb (I haven't taken apart a 1st gen cluster to know which it uses) is burnt out.
well. it could be the case.
I went to near by toyota service center. They could not seem to find the solution. They connected the obd II reader but it showed everything ok. Engine and ecu ok , airbag and abs ok as well. Even if it's the led, the obd should detect the problem which is not the case. What do you suggest? they also said the fuses and wires are ok. |
#4 | |
It is definitely not a fuse issue, as many other indicators would be out. 2004 meter connectors.jpg
this is the thing i need to tell the electrician as i haven't done it before. Apart from it, do you think of anything else which could be the problem. Please list the feared problems so i could tell my electrician to check.
I am fairly certain that it's a bulb rather than LED and that the bulb is burned out. I just noticed in the circuit diagram of the inside of the meter, that all of the indicators, except for water temp have the symbol for a bulb, rather than LED. Just the water temp indicator is drawn as an LED.
alright, i will get it checked. But it should not be the problem for starting engine. I will find some some other electrician and will update here if i find any solution.
#8 | |
For the not starting issue, you need a mechanic to go through the basics (fuel supply, spark, etc.)
i had my car parked in his garage. today i went and he had fixed that check engine light problem and said that he put relay in the car which was missing. he said it will take 3 to 4 long self starters (in the morning) to turn on the engine. if i need some proper solution he will open the HEAD of car, i avoided that thing. it seems like this is some big issue or mystery. i will try to start the engine in the morning and see if it gets any better.
| electrical problem with car need help badly!! | Adriaan | DIY / Maintenance / Service | 20 | 05-07-2010 12:40 AM |
| Custom Lftback - Photo-Scavenger Hunt | custom Lftback | Photo-Video-Media Gallery | 2 | 03-01-2009 11:12 PM |
| Photo Scavenger Hunt Ideas Thread | Black Yaris | Photo-Video-Media Gallery | 41 | 02-28-2009 08:54 PM |
