#91 |
Don't drive it, RALLY it!
Drives: 1999 echo PRC rally car Join Date: Oct 2008
Simple fix, block off the return, run max fuel pressure all the time that the pump can supply, run rich as hell and watch those injectors never get over 50% duty cycle
![]() And keep a back up supply of fuel pumps in the glove box for when they give up the ghost.
#92 |
greddy emanage ultimate. Still trying to talk to the tuner about all of this...
#93 |
Ok. Well I talked vaguely to the tuner via email and he suggested the walbro 255. however, i don't know if he is putting much thought into it or not whether i need to run a return fuel line or not. i mentioned it to him, but he didn't address it via email.
Question. Would the tuner be able to successfully tune with the walbro 255/larger injectors in place, and no return system? Wondering if i should just try the larger injectors first, and see if that fixes the problem. Then if not, get a larger fuel pump and go from there. I'll be going with the spec stage 2+ clutch and flywheel; also a Kaaz LSD. |
#94 |
injectors go on in minutes, you'll know if you're on the right track. Installing and running a fuel pump and especially a return line is a pain in the butt.
#95 | |
#96 |
![]() ![]() ![]() ![]() Drives: 08 Yaris Turbo; 06 tC Turbo Join Date: Jan 2010
I'm surprised pimp my yaris hasn't chimed in yet, as he's running the 255 with no problems.
Then again, he wouldn't have any excessively rich problems since he's tuning in open loop. And no reason to turn down the boost... Just don't drive really hard. I'm sure I'd be having the exact same problem if I threw my car on a dyno. Fact is, I have no plans to, and never see the need to exceed 4000 RPMs during daily driving. |
#97 |
Just put in a Spec stage 2+ clutch, Spec lightened flywheel, and Kaaz LSD. Feels gooooood.
ps: Sorry tamango. |
| Zage Turbo Kit Install - Toyota Yaris | Focus_Sh1ft | Forced Induction Forum | 160 | 02-06-2022 08:14 PM |
| Scion XB 1NZ-FE Turbo build | xbgod | Forced Induction Forum | 417 | 07-24-2011 09:16 PM |
| XBG's Total Build and Update Thread | xbgod | Performance Modifications | 10 | 11-18-2010 11:19 PM |
| Whats needed to turbo charge the yaris? | Arkhangel | Forced Induction Forum | 44 | 03-02-2009 10:08 PM |
