#19 |
^ wow the first post is of someone with a first gen 1ZZ manifold adapted to the 1NZ. Sweet.
#20 |
![]() ![]() ![]() Drives: jdm yaris sedan Join Date: Feb 2009
thats how we do tjings in pr lol
vvti bregao! |
#21 |
![]() ![]() Drives: Yaris 2010 Liftback Join Date: Feb 2010
If you use too much heat wrap, you will actually cool the manifold, which seems to be the effect you want. Otherwise, increase the pipe thickness, increase surface area, increase turbulent air flow, or increase the conductivity with a new material.
#22 |
oh wait, you mean too much heat is conducting to your manifold? in that case, any air gap/interface between the manifold and environment will be fine. And again, if you use too much heat wrap or insulation, you will have the opposite effect.
| Garm's CF Wrap | LA Yaris | California | 15 | 07-29-2010 07:01 PM |
| LEDs and heat | SaerinRhoe | Cosmetic Modifications (Exterior/Interior) | 10 | 01-02-2010 09:34 AM |
| heat barrier | auto pal | DIY / Maintenance / Service | 1 | 06-27-2009 05:29 PM |
| OEM foglight switch and leather wrap steering wheel | 808yarisLB | Cosmetic Modifications (Exterior/Interior) | 8 | 03-11-2009 12:05 AM |
| General Warning and Fuel Tank Heat Shield | ttufrosty | General Yaris / Vitz Discussion | 8 | 05-31-2007 10:59 PM |
