Old 12-31-2010, 06:58 PM   #19
H3LlIoN
Drives: '09 Yarrrr hatch
Originally Posted by TonyHanscomb View Post
Anyone know what power output to expect (or risk) just adding a good turbo to the stock 1.5 Yaris engine?
As far as I can ascertain the boost can just be turned up to produce whatever power one wants, until it self destructs.
It would be good to know how much it can take?
Also is there any inherent weaknesses that can be eliminated to allow higher boosts, such as forged pistons, different crank, special rods?
Also, the turbo won't self destruct, it'll just tear the engine apart. As for higher boost applications, Garm is running 24 psi with the mods previously mentioned, as well as a few others (block bored/sleeved/notced,standalone, fuel pump/rail, P&P'd head, etc.) If you have not already heard, tuning will be an issue at higher levels.
Toyota
Moving Forward
...even when you don't want it to.
Special thanks to Cali Yaris, 1NZYaris1 and lilredrocket
H3LlIoN is offline   Reply With Quote
Old 01-01-2011, 05:12 AM   #20
Parmas
Parmas's Avatar
Drives: Vitz RS Turbo
This question was posted too many times (including myself) and I think the question is too general since a stock 1.5 Yaris engine is made of several parts you need consider. We mainly focus on rods and pistons but they aren't the only issue to consider. You have to note the physicial inside parts of the head, head bolts and fuel delivery. These and more make a turbo project complete and not just a turbo!
That depends what turbo are you running. If you take a GT28 with an internal wastegate spring pressure that gives you 9 psi boost, the lowest maximum boost would be this and could be already fatal for you engine especially if not tuned.
There are much weaknesses that can be eliminated/ or upgraded to allow higher boosts that would be almost every part your engine has which in that case would cost you a fortune! That depends what are your intensions for the car and how much cash are you ready to invest!
This thread made me think...... how about gathering information from turbo or supercharged owners and list in divisions every stock part how much withstanded boost and power?
For example I have a complete stock Head and Crank that is running an efficient 9psi (don't know the exact power & not yet) on a GT28 turbo.
Old 01-13-2011, 10:56 AM   #21
Yoda
Yoda's Avatar
Drives: 2008 Black Sedan
Sounds like not too bad of an idea...Let me put one up
Yoda is offline   Reply With Quote
yaris ts 1.5 turbo Paris vvt-i Forced Induction Forum 31 03-14-2012 08:05 PM
IS IT SAFE TO RUN TURBO ON STOCK INJECTORS ? Faraz_Shaikh Forced Induction Forum 9 10-19-2010 04:01 PM
TURBO KIT for Yaris 1.3 or 1.5 Giupo Items for Sale by private party 27 01-22-2010 11:01 AM
HKS turbo timer type 1 Tamago Performance Modifications 3 07-21-2009 11:59 AM
