Old 12-30-2010, 09:13 PM   #1
gabriel2012
Drives: 2011 Base Sedan
A bit angry with alarm install
Okay so today I got my alarm installed but before I tell you about my problem I will talk to you about the cars in Puerto Rico
the base yaris comes with a factory alarm (activates when all doors are closed with the key,no remotes or anything) the tech package has alarm, power everything etc but I have the base model with power nada
Sounds secure right? 2 alarms YEAH!
Nope the car(stock alarm) thinks someone is breaking and goes off in every time I open it with the remote(aftermarket alarm)
is there anyway to disable the stupid useless stock yaris alarm? thanks!
http://db.tt/QIWZ2E2 Click to signup for dropbox, and get bonous space, I do too!
gabriel2012 is offline   Reply With Quote
Old 12-30-2010, 10:47 PM   #2
What is the stock alarm that comes on the PR spec Yaris? Is it the TVIP RS3200, with which there is a module to the right behind the lower passenger side glove box?
Old 12-31-2010, 04:01 AM   #3
big lo
big lo's Avatar
Drives: 2007 VIOS
The only change that I know is only the radio, the alarm set up is the same, So CT help the man, my dude he is calling for you bro
Old 12-31-2010, 06:40 AM   #4
gabriel2012
Idk if we have the same manual but I believe its explained there
I will have a look under the dash tomorrow night as I left to spend new years eve with the family
Old 12-31-2010, 09:17 AM   #5
gabriel2012
Hey scott I called the alarm guy and apparently the problem was that I was unlocking the rear hatch with the aftermarket alarm still armed.
but still is there anyway to at least disable the stock alarm? a fuse, wire or something?
Old 12-31-2010, 09:41 AM   #6
Palmer812
Drives: 2010 Meteorite Metallic LB
CTScott is very smart and may know of a better way but here is what I would do assuming it is the same as our U.S. Yari. Take the status output wire from the aftermarket alarm and hook it to the keysense wire in the car. That wire is yellow and has a - trigger. It can be found at the ignition switch or at pin 7 in the 14 pin plug in the fuse box under the dash. That will allow the aftermarket alarm to disarm the factory alarm.
Palmer812 is offline   Reply With Quote
Old 12-31-2010, 10:41 AM   #7
That's definitely may be one way of doing it.
Old 12-31-2010, 06:08 PM   #8
gabriel2012
I think I figured it out, what I did was to just lock and unlock the doors with the remote(aftermarket) and the oem alarm didn't come on, looks like if you use the keys on the doors you trigger it. the light on the dash has been off all day and I had around 10 unlock cycles getting last minute junk for new years.
so far so good :)
Old 12-31-2010, 07:44 PM   #9
H3LlIoN
Drives: '09 Yarrrr hatch
I looked at the wiring diagram for the unit he bought...it's pretty basic, and designed as a basic immobilizer for a car with no security system previously installed. It does not have wires for tying in to a factory alarm.
Toyota
Moving Forward
...even when you don't want it to.
Special thanks to Cali Yaris, 1NZYaris1 and lilredrocket
H3LlIoN is offline   Reply With Quote
Old 01-01-2011, 09:11 AM   #10
Palmer812
oh. But I assume it does have lock and unlock? If so he could use factory alarm arm and disarm wires instead of lock and unlock. That would lock and unlock the doors and arm and disarm the factory alarm both.
Old 01-01-2011, 01:14 PM   #11
H3LlIoN
yeah, it has lock/unlock, but that's the problem he has in the other thread. They used arm/disarm instead of lock unlock.
Toyota
Moving Forward
Customized car alarm suckerface In Car Entertainment + Electronics (audio / video / alarm) 4 04-12-2010 05:43 PM
Improving the 'range' of your existing alarm system ad23 General Yaris / Vitz Discussion 8 04-14-2009 10:12 AM
help me with my annoying alarm! misteo In Car Entertainment + Electronics (audio / video / alarm) 1 10-21-2008 01:49 PM
alarm install Lowfront In Car Entertainment + Electronics (audio / video / alarm) 5 09-12-2006 06:32 PM
