TRANSMISSION QUESTION - stick
I've noticed lately that when putting the car in first gear that it sort of snaps into gear rather than sliding into gear. Any way to correct this. are there any adjustments to the transmission
![]() Drives: Soon Join Date: Nov 2010
I know what youre talking about, i believe its that safty catch that makes it difficult to slide into first if youre above 20mph. Then again, ive had times where i KNOW my clutch was all the way out, and i still ground first (or what seemed to feel like it), i suspect its that safety mechanism.
you're in CT.. it's cold there right now. unless your transmission is warmed up, it's gonna be notchy as hell... does this happen all the time? or only when the trans is cold?
![]() Drives: 2007 Blue Yaris Join Date: Aug 2009
I live in So. Fla. every morning it seems to hesitate going into second gear. At 46000 I just changed the filter, fluid, and gasket still no change. I'm sure it's a warm up thing cause it doesn't do it after the first start up.
sounds like your syncro is taking a crap. very common in your transmission. have you adjusted your clutch?
your second gear problem has nothing to do with the 1st gear problem posted above.
| Question for Transmission Cooler | 33lam | Australia | 3 | 09-26-2010 10:54 PM |
| Transmission Question | CMR | General Yaris / Vitz Discussion | 42 | 04-14-2010 12:38 PM |
| Transmission Question | buddyjim | Performance Modifications | 14 | 04-13-2010 05:00 PM |
| Automatic Transmission Question | daf62757 | New YARIS Purchase Forum | 16 | 02-16-2009 10:41 PM |
| A question about the gas thingee -- the place where you stick the nozzle. | petesimac | General Yaris / Vitz Discussion | 11 | 07-18-2007 08:23 PM |
