#55 | |
![]() Drives: Yaris 2005 Join Date: Jan 2011
May I ask how you fixed it? I don't understand what 'total it' means in your summing up sentence "Thanks CT.... all i had to do was total it" :/ :) Cheers. |
#56 | |
With your, have you checked the bulbs? The most common reason for no low beams is that both bulbs have burned out their low beam filament.
#57 | |
I was thinking that the fact they both stopped working at the same time was too much of a coincidence, but the cost of new bulbs makes the most sense to test first. Cheers. |
#58 | |
What tends to happen is that one bulb dies, you don't notice it, and then the other goes. Before buying new bulbs, you could pop one out to make sure.
#59 | |
I think I should subscribe more to the principle of Occam's razor. Cheers :) |
#60 |
![]() ![]() Drives: 2013 Hybrid 1.5L T4 Join Date: Jan 2011
sorry to bother you mate, I think this thread is the gold mine off the search on the internet, am still a bit baffled up from where to start from what I've been reading off your posts. I noticed our 2006 yaris/vitz has just had its dipped lights/ normal driving lights go off. Over the past weeks I noticed occasionally that the lights went off and on/ flickered a bit during driving but then back on and remained during the trip, which cautioned me but as long as they seem to be fixed I didnt worry much. but now they'er off, kinda the car's not drivable at night. I checked both 10A H/L fuses under the hood which are fine, and the under the dash fuse 10A termed d/L still fine. anything in particular that strikes your mind? all other lights do work.
#61 | |
#62 |
No it's stock still with it's japanese stock headlights, we guess since there was a previous owner before us, but again the headlights seems stock. Again as I mentioned, a few weeks ago I witnessed the dipped lights go off whilst drive but back on a few moments later.
#63 | |
If you verify that they are not HIDs, then my next suspicion would be the headlight switch itself or its connector. On one of mine, a pin had gotten sloppy from too many times of the connector being plugged and unplugged, and my lights started flickering at night. I figured it out by driving with the lower steering column cover removed and when it would happen I could wiggle the wires and make them come back on.
#64 | |
I understand your point on wiggling the wires under the steering column, from our end I can recall that the last time steering column has been opened is like 3 yrs ago to fit the FM radio thingy that unlocks the FM european frequency on the factory headunit. Although now I've just remembered that I've replaced headunit to an aftermarket one like a year and a half ago, since the stock one had the touchscreen stop functioning. in other words that fm frequency chip can be removed I gues.. but again..I dunno if this is related. |
#65 | |
also in the post subject to moderation because of the image links, I did mention that the last tiem I can recall of opening up steering column was once like 3 years ago when we still had the stock double din touch screen factory headunit, in which I fitted an fm european frequency unlocker on the stock headunit, but after that like a year and a half ago touchscreen did stop functioning and had replaced it with an aftermarket kenwood one, which reminds me that now I dont need that chip any longer which is still in the column. but again this is years ago and I wonder how it could interfere. |
#66 | |
cheers for your help guys, especially you CTscott Ian - Malta |
#67 |
So, my wife and son come in from hockey practice and tell me that the hazard lights in our '08 started spontaneously flashing, accompanied by a fast "beeping sound". The doors were open and keys out of the ignition. Now my driver's side low beam and marker lights don't work. High beam does. Looks like I"ll be pressing my multimeter into service. Oh joy!
| DIY - Headlights off with the Ignition Switch | CTScott | DIY / Maintenance / Service | 46 | 11-03-2018 08:42 PM |
| aftermarket headlights | be_ha | Cosmetic Modifications (Exterior/Interior) | 0 | 10-03-2010 03:06 AM |
| Best Aftermarket Headlights | MadMax | Cosmetic Modifications (Exterior/Interior) | 3 | 06-04-2009 06:50 PM |
| Angel Eyes headlights | Danish Yaris | Cosmetic Modifications (Exterior/Interior) | 9 | 02-13-2009 09:15 AM |
| JDM headlights | yrsdrgn | Cosmetic Modifications (Exterior/Interior) | 6 | 02-13-2007 10:52 AM |
