Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Second Generation Toyota Yaris Main Rooms > Regional Forums > Middle East
Old 01-12-2011, 02:52 AM   #253
syntax
syntax's Avatar
Originally Posted by duke_afterdeath View Post
parang ikaw hindi rin nawala
wahahaha ang isang medyo nawawala si blue, busing busy ata or may sakit pa rin?
Old 01-12-2011, 03:35 AM   #254
rye7jen
rye7jen's Avatar
Drives: 2nz-fe '10
tol di na kami gumamit ng fuse kc sa lighter nag top si joni kaya may fuse na sya.. mga magkano kaya brand new ngaun nun? sama ka sa friday tol tirahin ulit natin
Pre, as per treb, iinit daw agad ang wire kung ittap lang sa cigarette light, kaya direct sa battery mismo setup niya. :Iono:
rye7jen is offline   Reply With Quote
Old 01-12-2011, 04:01 AM   #255
syntax
syntax's Avatar
pre' may mga wire ka na ba? mas maganda mas mataba ang wire para hindi sya nag iinit at kung balak natin lagyan ng independent fuse pwede rin. hindi tayo basta mag ttap issolder natin at may shrinkable tube para protected din.
Old 01-12-2011, 04:19 AM   #256
jonimac
jonimac's Avatar
Send a message via Yahoo to jonimac
Kung gusto nyo PRO ang dating, may power cable talagang nabibili for amps sa auto, set ito nasa SR90 sa AL AQSA meron.
jonimac is offline   Reply With Quote
Old 01-12-2011, 04:24 AM   #257
duke_afterdeath
duke_afterdeath's Avatar
Drives: 2008 Yaris Sedan
sa tingin ko nga dapat direct tayo sa battery mataba man ung wire natin pero ung sa lighter pansin ko manipis lang baka un ang uminit need pa natin ng fuse plus fuse socket wala me time bumili
duke_afterdeath is offline   Reply With Quote
Old 01-12-2011, 04:46 AM   #258
syntax
syntax's Avatar
pre sa tingin ko ok na kahit walang fuse kasi may fuse naman un boombastic nyo,
Old 01-12-2011, 04:55 AM   #259
jonimac
jonimac's Avatar
Tol, ilang watts (music power) yung SUB mo? palagay mo ilang ampere yan?
Old 01-12-2011, 05:10 AM   #260
duke_afterdeath
tol yung fuse ng boombastic 15amp not sure about the watts
Old 01-12-2011, 05:47 AM   #261
syntax
syntax's Avatar
@ duke diba nasa sayo naung parang leaflet/manual i think andun ata ung info. i diretso na lang natin sa battery pero hanap tayo ng way para hindi laging naka on ang boombastic mo.
Old 01-12-2011, 06:14 AM   #262
duke_afterdeath
tol sa lighter na ako magkakabit obserbahan na lang kung mag iinit
Old 01-12-2011, 06:35 AM   #263
syntax
syntax's Avatar
weehhh cge pre' dun pa rin tayo sa original na plano..
Old 01-12-2011, 07:18 AM   #264
rye7jen
rye7jen's Avatar
Drives: 2nz-fe '10
@syntax, sabi sa akin nung nagbenta nung sub, may nabibili daw di-metro sa batha (power cable,speaker wire) pati na rin mga fuse anf fuse holder. Pero hindi ko lang alam san banda dun.
@Joni, 100Watts yung boombastic. Se setup naman ni treb meron siyang nilagay na switch parang katulad ng fog light switch pero mas mataas daw dapat ang ampere not less than 10. Hindi na rin pala siya naglagay ng fuse in between the battery / sub.
Old 01-12-2011, 07:47 AM   #265
syntax
syntax's Avatar
sa mejdaf pre dami nyan hindi ko lang sure kung bukas ng friday...
Old 01-12-2011, 09:19 AM   #266
batman_john72
batman_john72's Avatar
Drives: yaris y 2010 blue
@ duke wahhahahhahhahah
@ batman gets mo na pre? wala na poste dyan, meron lang mga cement barricades na iiwasan mo na mabigat un eh hindi pwede i relocate wehehehehe
@syntax;cge tol lam q n un at kung maligaw man aq tawag nlng pra humingi ng tulong...whahahaha
batman_john72 is offline   Reply With Quote
Old 01-12-2011, 10:52 AM   #267
ubospawis
ubospawis's Avatar
Drives: Flint Mica 2010
baka makatulong tong link na ito. Electrical wiring manual.
http://www.etimago.com/yaris/repairmanual/EWD.pdf
Meron fuse socket na hindi ginagamit sa bandang baba, pwede gamitin.
Name:  Fuse block.JPG
ubospawis is offline   Reply With Quote
Old 01-13-2011, 01:08 AM   #268
syntax
syntax's Avatar
haist may pasok pa rin.. sarap sanang matulog ng matulog ... lamig lamig bbrrr...
Old 01-13-2011, 01:13 AM   #269
syntax
syntax's Avatar
just realized parang status sa FB ito ahh... wahahahhaha
speaking of FB, dami nag comment sa pic ni catwoman este ni batman ahhh... wahahahahahha
Old 01-13-2011, 01:35 AM   #270
xtremist
xtremist's Avatar
Drives: yaris Y 2010 A.K.A. "sky"
I think para safe both car and boombastic....bakit d nyo kaya lagyan ng "Circuit Breaker"?
Ciao !!!
Yaris X: The Largest Most Organized Pinoy Yaris Owners Group In The Middle East (Eastern Region Chapter)
Disclaimer: Not Connected to Toyota A.Lathif Jameel ME In Any Way
xtremist is offline   Reply With Quote
