Old 01-19-2011, 01:59 PM   #1
Attitude
Drives: Vitz
DOES BIGGER INTERCOOLER INCREASE PERFORMANCE
i have top mounted turbo yaris 1szfe, with gtti intercooler
now i am going for bigger intercooler used for front mount, but ill use still for top mount so please confirm if it increases performance
thanks
Attitude is offline   Reply With Quote
Old 01-19-2011, 07:15 PM   #2
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
It'll only help if you have more air going through the intercooler to cool it off. Do you have a hood scoop for airflow?
Old 01-19-2011, 08:24 PM   #3
xaero_81
Drives: 2008 Yaris LB Sport 5spd.
Seems to me that unless you've got a big turbo, you don't need a big intercooler.
xaero_81 is offline   Reply With Quote
Old 01-19-2011, 09:07 PM   #4
need more information. Are you doing anything else besides the intercooler?
Old 01-19-2011, 09:36 PM   #5
H3LlIoN
Drives: '09 Yarrrr hatch
I dunno, but I DID hear from an internet pop-up that there's a pill that can increase the size of.....Oh wait....nevermind. That wasn't about intercoolers.
Toyota
Moving Forward
...even when you don't want it to.
Special thanks to Cali Yaris, 1NZYaris1 and lilredrocket
H3LlIoN is offline   Reply With Quote
Old 01-19-2011, 09:39 PM   #6
Scubaru Steve
Awesome!
Drives: 12 Yaris/07 yaris
bigger is not always better, if the inter-cooler is not large enough or not enough air flow it will heat soak. if the inter-cooler is to big the pressure drop across the core will be huge and make less power then a properly sized.
with your current inter-cooler if you can do a couple on boost pulls back to back and touch the cold side of the charge pipe and its warm to cold it should be fine.
but no, going to a bigger inter-cooler is not always better. a properly sized for the application would be best.
Old 01-19-2011, 10:36 PM   #7
scioncrew
scioncrew's Avatar
Drives: SCION tC
Send a message via AIM to scioncrew
A intercooler is alot like a turbo. Two things you need to know. 1 is your end power goal. 2 how much physical space car has. You dont want to go too big you will start getting too much pressure drop. Here is Garretts cores sizes. Hope this help..
http://www.turbobygarrett.com/turbob...tercoolers.htm
05 Scion tC allmotor 350+ hp 9.34@144mph
05 Scion tC sfwd 880hp 9.96@147mph
05 Scion xB 280hp 12.97@104mph
07 Toyota Yaris 357hp 12.80@107mph
scioncrew is offline   Reply With Quote
Old 01-20-2011, 02:15 AM   #8
Faraz_Shaikh
Drives: Toyota Vitz
This the intercooler which i am planning to install, i am not having the hood scoop, but ill make it soon, turbo i am running is Garrett T28, .6 bar is the boost.
Faraz_Shaikh is offline   Reply With Quote
Old 01-20-2011, 05:51 AM   #9
cfeng
Drives: Yaris 2010 Liftback
more surface area might appear to mean more cooling. however larger intercoolers have larger piping or larger effective cross-sectional area, with lower flow. flow needs to be turbulent for increased heat transfer. also consider fin design for ideal spacing of fins.
to me it seems like more performance can be achieved with a better designed intercooler than a larger intercooler.
cfeng is offline   Reply With Quote
Old 01-20-2011, 06:13 AM   #10
Faraz_Shaikh
Drives: Toyota Vitz
oki thanks
The Yaris Performance Primer eTiMaGo Performance Modifications 31 10-20-2025 09:08 AM
>>>>>> Boxing Day Sale at TWM Performance; Short Shifters and Shift Knobs <<<<<< TWM Performance TWM Performance 0 12-24-2009 10:21 AM
OIL CATCH TANK increase performance? 33lam Performance Modifications 29 11-11-2008 01:08 PM
Do bigger wheels and tires improve performance Driver Wheels, Tires and Suspension Forum sponsored by The Tire Rack 14 10-14-2006 06:01 PM
