Old 10-18-2010, 01:29 PM   #1
CrzyCrg
Drives: 2006 Yaris T1
4AGZE Modification
Alright, here's the deal... I want to drop Toyota's 4AGZE engine into my Yaris. Does anybody have any idea how much different the mounts are? Also, some advice on a gearbox would be appreciated. I'm not too fussed about management etc because I'm going third party there. The only difficulty here is to get all the information to the heads up display. Will I have to change the dials from digital to analogue or is it possible to leave the sensors and what not where they are and just use the stock computer? I have a fair knowledge of programming, so if any is needed, with some research, time and patience, I can work it out. I just want to know where to start.
Shotalot!
CrzyCrg is offline   Reply With Quote
Old 10-18-2010, 02:56 PM   #2
cdydjded
Drives: Yaris LB Turbo
Shotalot!
Completely different. No one here has done a swap with that engine. The only engine swapped into a Yaris is the 2ZZ....
cdydjded is offline   Reply With Quote
Old 10-18-2010, 04:11 PM   #3
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
I think that there has been someone in Greece that did a Toyota 3S-GTE too. Your best bet is to do a search in the forum for either motor swap or engine swap. With that search you will find a few threads that you should find very useful.
Old 10-18-2010, 05:19 PM   #4
CrzyCrg
Thanks! I just got some info from another guy here in South Africa and he says that the 1ZZ-FE is probably the best way to go...
Old 10-18-2010, 05:20 PM   #5
CrzyCrg
Any other ideas?
Old 10-18-2010, 06:11 PM   #6
cdydjded
The 2ZRFE 1.8 would be a direct drop in. Comes in the Matrix, Corrola, xD & Vibe here in the states......
Old 10-18-2010, 09:44 PM   #7
fnkngrv
fnkngrv's Avatar
Yup...that would be a much better way to go most likely than the 1zz.
Old 01-15-2011, 02:40 PM   #8
CrzyCrg
the time's coming! i will do some research and see if the 2zrfe is available in sa! thanks guys!
Old 01-25-2011, 12:12 PM   #9
CrzyCrg
Definitely going to go with the 4AGZE engine due to the fact that I'm going to turbo the engine come the end of the year! Thanks guys!
Old 01-25-2011, 12:53 PM   #10
heeroyuy01195
Post count means nothing.
Drives: AW11, NCP91, Old Motorcycles
Why not just swap in a 2zz or 1zz? The mounting points are virtually the same as that of a 4ag (Requires a slight elongation of the holes for the motor mount on one of the sides...can't remember which right now). Newer motor that will build way more power than a 4ag ever will.
heeroyuy01195 is offline   Reply With Quote
Old 01-25-2011, 02:07 PM   #11
I saw one in a local magazine some time ago.... though they did change for a turbo setup rather than supercharged. No idea of how much fabrication was involved, though.
Old 01-25-2011, 02:59 PM   #12
I think turboecho2005 did. He had to do quite a bit of frame modification to make that happen.
Old 01-25-2011, 03:05 PM   #13
severous01
if you're goin that far, why not throw in a ls7 or ls9 in there??? tunnel the center for a driveshaft and use the corvett or porsche trans/diff in the rear....with independant suspension. it's feasible.
or, throw in the turbo mr-2 engine in there? or, throw in the b-20 honda engine.
Old 01-25-2011, 04:30 PM   #14
Nexus1155
Bathroom + Laptop = <3
Drives: Audi
or why not some RX-8 rotary engine I remember being talked about in a previous thread
Old 01-26-2011, 01:20 PM   #15
turboecho2005
turboecho2005's Avatar
Drives: 2005 Toyota Echo
Frame rail modification is required. I have a thread in the forced induction section. There should be a link to the build photos. Just drop in an ls9 motor and call it a day ;).
Project Slowtop - Twin Engine 4AGE Blacktop Vitz - Twin Turbo - 503hp
1987 Nissan Maxima - 40,000 original miles - Slammed
1991 Isuzu Impulse RS AWD Turbo - approx 250hp - Winter Beater
1989 Isuzu Imark RS - Mint Condition - 0 rust - 100% factory :) - Summer Cruiser - 100% restored
1986 VW Jetta Wolfsburg - 120,000km - Mint condition. TDI swap in progress
turboecho2005 is offline   Reply With Quote
Old 01-26-2011, 01:37 PM   #16
Yaristeve
Drives: 3-door hatch
Or, how about what Renault did with their LeCar -> R5 and put the MR2 drivetrain in the back seat area. There was also a short run of "SHOgun" by some company: Yamaha V6 from the Taurus SHO into the back seat area of a Festiva.
Old 01-26-2011, 02:41 PM   #17
2zz and 1zz require frame rails to be cut as the engine/transmission together is wider
would a 4agze still be a 4agze w/o the s/c? lol
a friend of mine has a s/c'd mr2 (subsequently a 4agze is in it). the s/c went kaput, so he turbo'd it. it already has the strong internals meant for boost, so its an ideal candidate to be turbo'd rather than supercharged...
Old 01-26-2011, 02:43 PM   #18
CrzyCrg
main reason for going with the 4AGZE is the internals... here, it would put another 20 to 30000 onto the modifications... i can pick a 4AGZE up with the supercharger for 7500... i will turbo it later so instead of spending 60000 to turbo, i'm only looking at 25000 to 30000....
Front seat modification. Increase thigh support. PetersRedYaris DIY / Maintenance / Service 36 08-22-2018 02:37 PM
Factory Miata wheels fit without modification? evan Wheels, Tires and Suspension Forum sponsored by The Tire Rack 22 07-02-2015 09:01 PM
Automatic headlight modification to add taillights Snowy DIY / Maintenance / Service 8 09-18-2010 11:47 AM
Bigfoot modification and Weathertech floor mats bitz767 DIY / Maintenance / Service 5 02-10-2010 10:31 AM
Simple modification yielded 4 mpg Bob_VT Fuel Economy Forum 9 03-25-2009 09:35 AM
