Old 01-26-2011, 01:06 PM   #91
sqcomp
Roadrunner Jr.
sqcomp's Avatar
There are two camps to the buying idea. I'm on one side which supports brick and mortar stores.
PM me your address. I think I can match that woofersetc ebay price on the HSK 163 set and get it to you for basically the same price overall. That way you'd have a real factory warranty for the same price as the rip off woofersetc 9 month in house (non authorized) "warranty".
I'm thinking that the second set is an older set. That's an attractive price as I'm seeing it for the two way. It's old however...
― Thomas Paine
Old 01-26-2011, 07:42 PM   #92
sickpuppy1
Drives: 2010 Yaris Sedan
Gotta figure in the 50.00 shipping too!
Old 01-26-2011, 07:59 PM   #93
Palmer812
Drives: 2010 Meteorite Metallic LB
FYI! I don't know of anyone personally that has ordered Hertz from Woofers Etc. but according to Electromedia USA (Hertz/Audison) Woofers Etc. doesn't even have any Hertz speakers at all. Period. They wanted to be a dealer and Hertz refused to sell to them and they got mad. They still advertise that they have it but when you order ut they (bait and switch) you. They do however have some older Audison amps they acquired from a dealer who went out of business. Hertz/Audison refuses to warranty ANYTHING that comes from them.
Palmer812 is offline   Reply With Quote
Old 01-27-2011, 12:04 AM   #94
derickveliz2
derickveliz2's Avatar
Drives: Yaris Sedan "S"
Thumbs up
Nice looking amp! Is everything going okay with it? (customer service checkup)
Thank you,
Yes every thing is OK, a big improvement from my old Premier Pioneer amp.
One question, it makes a little noise when turns on/off on the speakers, my Pioneer amps never did, when on sounds like "Thrrrst" and when off sounds like "Tukk"
listen to this VIDEO...
or...
http://www.youtube.com/watch?v=HvFqMbs5VN0
Thanks
D.
CLA 250, 4MATIC
Old 01-27-2011, 12:07 AM   #95
sqcomp
Roadrunner Jr.
sqcomp's Avatar
@Palmer...
That is EXACTLY what my shop owner said! Bait and switch.
@Derick:
Check your grounds carefully. In order for the amps to function properly, the audio ground must be referenced to chassis ground at the source unit. If it is not, the amplifier could oscillate. To check for a good ground reference, take a volt-ohm meter (VOM) and measure the resistance between the chassis of the radio and the shield of the RCA line level outputs of the radio. This reading should indicate a direct short. If this is not the case, grounding the shield of the RCA line level outputs to the chassis of the radio will probably be necessary. Keep amplifier power ground wires as short as possible. The longer a wire, the more resistance it has. When a current flows through a resistance, a voltage drop is produced. Because of this, the ground reference at the amplifier's circuit board is no longer the same as that at the chassis of the vehicle. This ground potential differential can lead to noise and improper operation of the amp. (-W.H.)
I'll show Jim this if we can't solve this soon.
― Thomas Paine
Old 01-27-2011, 08:55 PM   #96
packetrace
packetrace's Avatar
Drives: Yaris Sedan 2009
Welll....looks like ebay wont be a great choice....:O I'll forget ebay buying !
Interior:ALL red, black roof
Old 01-28-2011, 09:37 AM   #97
packetrace
packetrace's Avatar
Have you seenn this yaris build on DIYMA ???
Old 01-28-2011, 11:15 AM   #98
sqcomp
Roadrunner Jr.
sqcomp's Avatar
What build? Derick's?
― Thomas Paine
Old 01-28-2011, 12:18 PM   #99
packetrace
packetrace's Avatar
http://www.diymobileaudio.com/forum/...ris-build.html
Old 01-28-2011, 09:12 PM   #100
sqcomp
Roadrunner Jr.
sqcomp's Avatar
I remember this install. at some point I had communication with the builder on this one. There were some suggestions on the door assembly...
― Thomas Paine
Old 01-28-2011, 10:39 PM   #101
sickpuppy1
Sorry to interrupt....But what is the third harness for?LOL the new Pioneer has two plugs that get soldered together with the harness for the radio, and connect to the Yaris' plugs, but the old radio had three going into the back of it, so one harness isnt used.....Ideas?
Old 01-29-2011, 01:27 AM   #102
derickveliz2
Exclamation
Yes I've seen it, he started posting here in YarisWorld, like Sqcomp mentions he gave him some advice to repair his cracked doors.
I've been trying to condense my installation in a very simple photographic way in DIYMA...
here is the LINK
D.
CLA 250, 4MATIC
Old 03-30-2011, 12:31 AM   #103
derickveliz2
Exclamation
packetrace
I found the ring for the tweeter that was missing, send me your address again I'll mail it to you!
D.
CLA 250, 4MATIC
ACRONYM thread Shroomster Off-topic / Other Cars / Everything else Discussions 45 02-15-2025 10:30 PM
Yaris Sedan Deadening and Sound system upgrade derickveliz2 In Car Entertainment + Electronics (audio / video / alarm) 2992 11-18-2021 02:14 AM
Electrical System Upgrade Advice sqcomp In Car Entertainment + Electronics (audio / video / alarm) 6 03-23-2016 01:15 AM
Very Important Question about Sound System Upgrade. Falconeer In Car Entertainment + Electronics (audio / video / alarm) 5 07-07-2010 03:57 AM
Cheap sound system upgrade. I like it. kac In Car Entertainment + Electronics (audio / video / alarm) 11 06-22-2010 09:48 PM
