Old 01-26-2011, 02:43 PM   #19
CrzyCrg
Drives: 2006 Yaris T1
Originally Posted by turboecho2005 View Post
Frame rail modification is required. I have a thread in the forced induction section. There should be a link to the build photos. Just drop in an ls9 motor and call it a day ;).
I have a 2006 model Yaris though, so do you have any idea what's gonna happen there?
CrzyCrg is offline   Reply With Quote
Old 01-26-2011, 02:47 PM   #20
CrzyCrg
2zz and 1zz require frame rails to be cut as the engine/transmission together is wider
would a 4agze still be a 4agze w/o the s/c? lol
a friend of mine has a s/c'd mr2 (subsequently a 4agze is in it). the s/c went kaput, so he turbo'd it. it already has the strong internals meant for boost, so its an ideal candidate to be turbo'd rather than supercharged...
That's the plan... looking at the Garret GT3076 turbo... or possibly the equivalent of their GTX3076 which is made by Precision Turbo... I'm lokking at around 200kW on the wheels with this setup, which isn't bad for a car that wiehgs just under a ton...
Old 01-26-2011, 02:51 PM   #21
CrzyCrg
for now i can change the supercharger pulleys and pull about 0.7 bar (10psi) boost of the supercharger which should put me at about 170kW (+- 230 hp)...
Old 01-26-2011, 03:01 PM   #22
CrzyCrg
so, checked out the ls9 engine... apart from the fact that it probably wouldn't be available in south africa, A 6.2 LITRE SUPERCHARGED V8 IN A YARIS!!!! one can only dream :-p
Front seat modification. Increase thigh support. PetersRedYaris DIY / Maintenance / Service 36 08-22-2018 02:37 PM
Factory Miata wheels fit without modification? evan Wheels, Tires and Suspension Forum sponsored by The Tire Rack 22 07-02-2015 09:01 PM
Automatic headlight modification to add taillights Snowy DIY / Maintenance / Service 8 09-18-2010 11:47 AM
Bigfoot modification and Weathertech floor mats bitz767 DIY / Maintenance / Service 5 02-10-2010 10:31 AM
Simple modification yielded 4 mpg Bob_VT Fuel Economy Forum 9 03-25-2009 09:35 AM
