Old 01-27-2011, 09:56 AM   #1
xartrax
Drives: 2007 Yaris Hatchback
one brake light out
Hi
got a trafic ticket...one brake light out.
I replaced the bulb but the driver side brake light is still out. (the tail lights are both working).
My next step would be to check the fuses. I have located the fuse box for the lights.
My question is: would it be a fuse if only one brake light is out? in other words, isn't there just one fuse for the brake light circuit, which includes both brake lights????? seems odd that just one brake light is out.
If its not a fuse, any other suggetions?
xartrax is offline   Reply With Quote
Old 01-27-2011, 11:11 AM   #2
severous01
not fuse...probably the socket. check for burn marks and bent pins/tabs. happens all the time. maybe not on toyota but it's still a likely source. you can also ohm out the wires and see if it's shorted to ground or if ground is shorted to pos.
Old 01-27-2011, 12:02 PM   #3
MadMax
MadMax's Avatar
Are you running the stock tail light assemblies and bulbs?
Cheers! M2
Old 01-27-2011, 01:40 PM   #4
sex
sex's Avatar
Drives: 09 5DR
Check page 135 on the 'electrical wiring diagram'. Looks like both tails share the same fuse. Do your license plate lights work?
sex is offline   Reply With Quote
brake light fuse
The Basics on Brake Upgrades kngrsll Performance Modifications 56 03-06-2024 09:50 AM
HELP! ABS & BRAKE LIGHT ON SIMULTANEOUSLY! mizhgolightly DIY / Maintenance / Service 45 05-03-2022 03:59 PM
How many forum posters does it take to change a light bulb? silver_echo Off-topic / Other Cars / Everything else Discussions 25 06-27-2011 02:50 AM
Emergency brake light is on constantly AdeJong 03 DIY / Maintenance / Service 9 10-10-2009 10:32 PM
Dealer: Disabling the seat belt chime is now illegal? schleppy Cosmetic Modifications (Exterior/Interior) 13 04-18-2009 05:43 PM
