Old 05-18-2010, 10:41 AM   #1
leinadeb
leinadeb's Avatar
Drives: 2001 Toyota Vitz Rs
How much to boost a 2nzfe engine..
Can anyone tell me the maximum boost that a 2nzfe can hold without making any damages to the engine please? Thanks
leinadeb is offline   Reply With Quote
Old 05-18-2010, 11:07 AM   #2
has the same compression ratio (10.5:1) as the 1nzfe
i wouldn't go more than 8psi on stock internals
Last edited by thebarber; 05-18-2010 at 02:30 PM. Reason: i can't spell, apparently
Old 05-18-2010, 02:17 PM   #3
cdydjded
Drives: Yaris LB Turbo
Id agree on the above statement
Old 05-18-2010, 02:46 PM   #4
+1
And it depends on how you drive. If you do a season of racing @ 8psi on a stock motor, you might definitely see some engine damage.
You will have some measure of reduced engine life though, e.g., it's not going to run for 100,000 miles like that, just to be clear.
(but the miles you get will be REALLY fun)
Old 05-18-2010, 07:23 PM   #5
Astroman
Modded Moderator
Astroman's Avatar
Moved this to the forced induction section.
Old 05-24-2010, 08:11 PM   #6
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
It can probably hold 1 or 2 psi more than the 1NZ because it has a slightly shorter stroke... 11.2mm shorter.
Old 05-24-2010, 09:58 PM   #7
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
Some one send me a kit and we will find out
Old 01-28-2011, 01:16 PM   #8
crolandiz
Drives: Yaris Sedan '08
Hi, but what is the better? Turbo or Supercharger for a 1.3l 2NZ-FE Yaris?
Greets.
crolandiz is offline   Reply With Quote
Old 01-28-2011, 02:34 PM   #9
without getting into the pros/cons of anything other than the end result:
turbo > supercharger
Old 01-28-2011, 02:36 PM   #10
crolandiz
And what is aprox the max HP I can get with a turbo on a 1.3 with std internals?
Old 01-29-2011, 12:35 AM   #11
xixarchangelxix
The Unicorn
xixarchangelxix's Avatar
Drives: 2006 Yaris 5D HB
As much HP as 8 psi gives you with your specific build and tune.
xixarchangelxix is offline   Reply With Quote
Old 01-29-2011, 03:25 AM   #12
Faraz_Shaikh
Drives: Toyota Vitz
what about 1s zfe? how much boost it can hold on stock internals ?
Faraz_Shaikh is offline   Reply With Quote
Old 01-29-2011, 11:44 AM   #13
^ I don't think anyone knows this for sure. Do it, then tell the rest of us.
Old 01-29-2011, 11:46 AM   #14
Yoda
Yoda's Avatar
Drives: 2008 Black Sedan
What's the compression ratio on that engine? From that u can give u a gusse
Old 01-29-2011, 12:32 PM   #15
Bluevitz-rs
The same as the 1NZ > 10.5:1
Old 01-29-2011, 12:54 PM   #16
I made 180 whp on 8-9 psi on my stock 1.5L 1NZ-FE.
with a little less displacement, you'd get a somewhat lower number, everything else being equal?
DIY: Intake Installation redyaris DIY / Maintenance / Service 53 08-23-2014 05:34 AM
Remote Engine Start PT398-33070 Reeves360 In Car Entertainment + Electronics (audio / video / alarm) 3 08-26-2009 07:11 PM
The last gas question Tonavi DIY / Maintenance / Service 56 04-27-2009 08:40 PM
