Old 01-29-2011, 12:09 PM   #1
Nips
Nips's Avatar
Drives: BMW 3 Series M Sport
Wheel Spacers
Hi, i have done a search and read some of the topics on wheel spacers but want to double check before buying
What mm can i go to before having to change the wheel bolts?
im going for 5mm on the front and was think 10mm on the rear.
Will these be ok?
http://www.performancealloys.com/spa...ls.aspx?ID=191
All the spacer for sale for my model of yaris
http://www.performancealloys.com/all...PCDID=33&tab=3
Any help will be appreciated
Nips is offline   Reply With Quote
Old 01-29-2011, 12:18 PM   #2
You can get away with stock studs for 5mm (though I'm not recommending it). 10mm will require longer studs.
Old 01-29-2011, 12:28 PM   #3
Nips
Nips's Avatar
Ok thanks, the studs are on the hub so what will i need to buy to add 10mm spacers
other cars i have had you just by longer bolts/nuts
Old 01-29-2011, 01:42 PM   #4
severous01
if your'e doing the 10mm inthe rear why not do the penguin spacer back there and not between the rim and drum.
the penguin spacer goes behind the backing plate. can be installed permanently in less than 30 minutes (assuming you inow what you're doing...), and dont damage/threaten the studs in any way. you can even go 13mm if you want
Old 01-29-2011, 02:22 PM   #5
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
+1 - Go Penguin.
Old 01-30-2011, 03:34 AM   #6
Nips
Nips's Avatar
Ok, Penguin it is.
Just sent an email to micro image for shipping cost to the uk
Thanks for you help guys
Old 01-30-2011, 05:16 PM   #7
Nips
Nips's Avatar
I'm now thinking of getting 10mm Ichiba Wheel Spacers for the front and 13mm penguins for the rear would this be a good set up for standard 17" SR wheels without any rubbing or catching?
Old 01-30-2011, 05:58 PM   #8
^ this depends on the offset of the wheel and the tire being used, and also camber. A little negative camber goes a long way to eliminate rubbing (and improves handling too!).
It may be necessary to trim some fender liner away in spots to eliminate any rubbing.
Old 01-30-2011, 06:07 PM   #9
Nips
Nips's Avatar
Ok thanks for your advise, but as a set up 10mm at the front and 13mm at the rear is this a good starting point?
the wheels are 215/45/r17 not sure what the offset is
Thanks
Old 01-30-2011, 06:21 PM   #10
Not withstanding the critical offset number, here is one thing to keep in mind.
Installing 10 to 13mm spacers in the back will bring the rear wheels more inline with the fronts. Installing 10mm in the front will continue to push the wheels out further than the rear.
If you are looking for cosmetic symmetry front to rear, then I would not put anything on the front. What is your ultimate goal?
Old 01-30-2011, 06:29 PM   #11
Nips
Nips's Avatar
Main goal is for the rear to fill out the arch and better handling, i intend to add strut braces in the future but have no plans to lower the car at this point because i want to keep the ride comfortable.
Lowered every previous car i have owned and don't want a back breaking ride, plus UK roads are shit compared with US roads from what i've seen
Old 01-30-2011, 06:30 PM   #12
Nips
Nips's Avatar
How would i find/work out the offset?
Old 01-30-2011, 06:53 PM   #13
^ you can either look up the wheel online, or it might be cast into the back of the wheel.
Or you can post a few pics of what it looks like now, so we can all comment, discuss, and nitpick the whole thing -- which is great for you.
Old 01-30-2011, 07:17 PM   #14
Nips
Nips's Avatar
Hopefully this will help
Old 01-30-2011, 07:59 PM   #15
Altitude
Altitude's Avatar
I've got 215/35/18 with a 42(or maybe 45) offset and I installed the 10mm Penguin spacers on the rear. No spacers on the front. Looks great!
Old 01-31-2011, 12:02 PM   #16
Nips
Nips's Avatar
Got any pics?
Just awaiting a reply from micro image, i think i will order 13mm peguins for the rear and leave the front standard
Old 02-05-2011, 02:36 AM   #17
matthewai
matthewai's Avatar
Drives: it is kinda stock
yeah do you have pics altitude i was thinking about this mod as well
Old 10-12-2011, 11:46 PM   #18
ArmyYaris
Drives: Blazin' Blue 2007 Yaris LB
What spacers would you reccomed for the stock 15's?
ArmyYaris is offline   Reply With Quote
25 mm Wheel spacers Rnankoo Wheels, Tires and Suspension Forum sponsored by The Tire Rack 24 03-22-2011 07:58 PM
Done! D2 Brake System, Tein Springs and H&R Wheel Spacers Installed RedVitz Photo-Video-Media Gallery 18 10-09-2010 03:36 PM
Installed 10mm PG spacers on a 15x7 +25 wheel kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 08-27-2009 07:10 PM
Steering Wheel Spacers? BassAssassin Cosmetic Modifications (Exterior/Interior) 0 08-12-2009 12:52 PM
