![]() Drives: 2007 Yaris Sedan Join Date: Jan 2011
Hi all,
The other day, I stated my Yaris and noticed that the ABS and brake warning lights stayed on. So I looked in the owners manual and it said to take the vehicle to the Toyota dealer. So I called my local dealer and spoke with an advisor and told him about the warning lights. He said that I could drive the car to the dealership. The next question, I had was how much would it cost since I had 74K miles on it and no extended warrantee. They said there is a minimum diagnostic charge of $100 to look at this issue (applied to the repair). Instead I went online to look to see if anyone else had this issue. I found posts on this website and followed the procedure on Axle maintenance, section AH-14 (part of the Toyota Yaris maintenance manuals) about the faulty rear skid control sensor connection. In my garage, I jacked the right rear end of my car to take a look. I did not remove the tire since the sensor connector wire can be accessed without removal of the tire. I used a small screw driver to insert it in the bottom most part of the sensor below the clip, then angled the screwdriver up. Then the sensor could be pulled off. I cleaned it with a rag then applied dielectric grease to the black plastic where the parts mate. I reconnected the sensor then repeated for the other side. As soon as I turned on my Yaris, I noticed that the warning lights are off. I hope this helps someone else. |
Wish I saw these pics sooner
It's outlined with some good pictures in this thread:
http://www.yarisworld.com/forums/sho...=11533&page=13 |
| Tags |
| yaris abs brake sensor |
| HELP! ABS & BRAKE LIGHT ON SIMULTANEOUSLY! | mizhgolightly | DIY / Maintenance / Service | 45 | 05-03-2022 02:59 PM |
| Brake warning lights !+ABS | tomrom101 | DIY / Maintenance / Service | 40 | 12-29-2013 09:20 PM |
| abs light + hand brake light on | stu 1 | UK | 4 | 09-28-2012 05:07 PM |
| Yaris Brake Grinding | Mike R | DIY / Maintenance / Service | 4 | 07-12-2010 10:19 AM |
| ABS LIGHT & E BRAKE LIGHT | rossman | DIY / Maintenance / Service | 5 | 02-25-2010 11:09 PM |
