Old 02-13-2011, 12:59 PM   #145
PumpkinSteve
PumpkinSteve's Avatar
Drives: Yaris SR 1.8
I'm glad someone mentioned that the sway bar will reduce understeer because that's one of my main complaints.
PumpkinSteve is offline   Reply With Quote
Old 02-13-2011, 04:41 PM   #146
matthewai
matthewai's Avatar
Drives: it is kinda stock
seriously i need those orig pics i wanted to check this before i get under there damn they are still gone?
Old 02-14-2011, 11:42 AM   #147
tk1971
tk1971's Avatar
Just installed the UR bar from MicroImage this weekend. It literally took one day to get to me (also in SoCal).
I installed it without jacking up the car and removing the wheels at around 11pm on Friday night, so I didn't get a real good look at how it fit. All I needed were racheting box wrenches (14mm & 17mm) and a torque wrench with 14mm / 17mm sockets.
Anyway, just want to mention 2 things that may or may not have been mentioned before regarding the swaybar:
1) It took longer to peel that saran wrap off the bar (the bar is completely wrapped in it) than it did to install it.
2) I had to loosen up the bolts and pull the bar down further after a test drive (there's at least 20mm of adjustment available). I initially had one end of the bar almost touching the rear torsion beam. During the test drive, it would touch and clank. Loosened, pulled the bar way down, then re-tightened. All is well.
tk1971 is offline   Reply With Quote
Old 02-14-2011, 11:54 AM   #148
^ good to know about the range of position.
I'm not responsible for the saran wrap. I guess it helps prevent scratching, they come all the way from Malaysia!
Old 02-17-2011, 10:18 PM   #149
racerb
One quick question for you guys, I've raced several different brands of front drive racecars, all that I've removed the front swaybar completely. Will the Yaris handle better with this setup, or has anyone tried this on their cars. I'm wanting to buy a Yaris very soon, but would kinda like to know up front what mods work best!!
My previous racecar was a Nissan Pulsar, that when in race trim had a 7/8" rear sway and Carrera inverted shocks set at max and a set of SSS Blue-Coil 295 ft.lb. springs. The front was a set of custom struts with coil-over 350 ft.lb. springs and Koni Sports inserts, with the front swaybar removed, the car handled like a go-cart. Any advice on what works best would be great!!
racerb
'86 Celica GT
'87 Celica GT-S
'98 Rav4L
'01 Tundra SR5
Old 03-02-2011, 01:58 PM   #150
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
cant see photos
Today we installed an Ultra Racing rear sway (anti-roll) bar on Babie Y's Yaris. I took a few pics, hope this is helpful.
First, jack up the back of the car (from the sides) and remove the rear wheels. This makes it easier to get to the bolts later.
Then, get out your sway bar. A friend, helper, bodyguard or whatever helps.
Look under the car. There is one large bolt holding the bottom of the rear shock. You can re-use this bolt. There is also a hole that isn't being used just in front of it, like this:
Here is the same two holes, shown from the inside angle instead:
Remove the bolt holding the shock. Place the swaybar with the bar at the bottom and so the holes line up. Re-install the bolt through the shock, then the sway bar, then a washer and nut. ***It is easier to do both shock bolts first, leaving the sway bar hanging -- then do the two front bolts.
That should look like this:
And like this:
Tighten and/or torque the nuts and you're done. In another thread there was consensus that "making them tight, but not crazy tight" was good enough for this.
thanks to supmet:
Go drive the car, high-five your bodyguard... and have a nice day.
* (check and re-tighten, if needed after driving for a few days).
* the Ultra Racing sway bar comes with hardware -- I'm sure the TRD one does, too.
* Yes, that is a Tokico shock.
Old 03-04-2011, 12:08 AM   #151
bB2NER
My Box and Her Egg
bB2NER's Avatar
Drives: 05' Scion xB / 08' Yaris 3dr
Tell me about it! That wrap had no rhime or reason to the way it was wrapped. Took almost 15 minutes.
I'm heading out now to bolt it on. Thanks for the info. on positioning.
I'm wondering why it comes with 4 bolts and only needs 2?
bB2NER is offline   Reply With Quote
Old 03-04-2011, 09:07 AM   #152
Imagine
Insert sarcasm here.
Imagine's Avatar
Drives: 2009 Black Pearl Sand 3Dr
Ordered mine yesterday, I can't wait to get it installed!
Imagine is offline   Reply With Quote
Old 03-04-2011, 01:38 PM   #153
marcus
toyota
marcus's Avatar
ordered mine 2 days ago...wonder how long it takes to get here in T.O.
Old 03-04-2011, 03:22 PM   #154
it's being picked up today, figure 6-10 days, maybe a little faster
Old 03-04-2011, 05:46 PM   #155
bB2NER
My Box and Her Egg
bB2NER's Avatar
Mine took almost a week to get UPS.
Got it mounted last night and all I can say is WOW! Major difference and huge bang for the bucks. The car is tight now, tracks straight and corners almost flat even with the stock springs/struts.
I highly recommend this mod!
Old 03-04-2011, 07:05 PM   #156
marcus
toyota
marcus's Avatar
lol.. no rush garm as long as i get it before april...thanks.
Old 09-14-2011, 01:19 PM   #157
aucorium
AKA Samurai Racer
aucorium's Avatar
Drives: Yaris 2006
any pics from the back of the car with it installed ? im looking at getting one now as my next suspension mod.
JDMtuner
Import Performance Tuning
www.jdmtuner.co.za
Old 09-20-2011, 02:40 AM   #158
Yaross
Yaross's Avatar
Drives: 2006 Yaris HB 5DR
Installed mine last night (UR 19mm)! 10 days shipment from California to KSA, not bad! Thanks Micro Image!
Haven't tested it fully, but yes, I got more response from the steering.
I am already expecting that my driving habit will change in coming days.
Yaross is offline   Reply With Quote
Old 09-20-2011, 03:12 AM   #159
kiel12
kiel12's Avatar
Drives: 2011 toyota yaris Y
yaross..picture pls..
kiel12 is offline   Reply With Quote
Old 09-20-2011, 02:59 PM   #160
Yaross
Yaross's Avatar
as requested...
Old 09-20-2011, 06:39 PM   #161
Hamster
Hamster's Avatar
Drives: 2009 5-Door Liftback
I enjoyed looking at the pics that show how to install the sway bar. Ultimately, I couldn't do it myself, thought, since I'm a girl, and I just don't have the strength to lift the sway bar. I had to pay a shop $100 to installed it. So, if you're capable of doing it yourself, do it, since it'll save you a lot of money.
Hamster is offline   Reply With Quote
Old 09-22-2011, 12:42 PM   #162
ocs811
Drives: 2009 yaris HB
Just installed my UR 19mm sway bar, shipping was fast and reasonable to Canada. Thanks Garm for giving us Yaris owner alternatives to TRD.
ocs811 is offline   Reply With Quote
Rear Sway Bar Instructions - Additional Pics SeaYa Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 02-26-2009 01:05 PM
TRD rear sway bar...street or race setting? detroiter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 14 02-08-2009 02:26 AM
TRD Rear Sway Bar Install ?? bikegerm Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 12-26-2008 01:46 AM
solid torsion bar bushings... the best rear anti roll upgrade turboyaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 28 12-05-2008 11:37 PM
DIY - TRD rear sway bar kurokoma-kun DIY / Maintenance / Service 0 10-20-2008 01:21 PM
