Old 03-25-2010, 07:20 PM   #73
FSANE
FSANE's Avatar
Drives: 07 4d yaris and 02 Trans Am
im looking at going LED for my tails, the 7443 led's are those duel brightness? so when there on and when you brake?
can I just get any 7443 LED or does it have to say Duel?
i have the same problem. I bought a set of 7443 LEDs. When brakes are on, they work, but when they are suppose to be on during regular night driving, they don't work.
02 T/A AUTO Metalic Silver. 07 Yaris M5.
Best ET is 11.13 @ 120 MPH with 1.47 60FT
11.13 sec vid
BurnOut Vid
FSANE is offline   Reply With Quote
Old 04-06-2010, 02:21 AM   #74
Emerge
On a trek to upgrade...
Drives: 2003 Echo Coupe
http://cgi.ebay.com/ebaymotors/ws/eB...1416&viewitem=
Are these any good?
Emerge is offline   Reply With Quote
Old 05-19-2010, 04:28 PM   #75
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Yes, you must get the duel...what they end up doing is linking some of the LEDs that will run off the brake circuit and they some of them will be the parking light circuit.
Old 05-19-2010, 04:49 PM   #76
fnkngrv
fnkngrv's Avatar
Well I just replaced my rear signal bulbs with 24 LED green bulbs...guess I will see how long before I get pulled over.
Old 09-11-2010, 12:57 AM   #77
sleey0
Drives: 2008 Yaris LB
Can anyone tell me WTF! kind of bulb goes into the headlight housing - and not the H4 main bulb nor the turn signal.
There is a smaller one with a special connector on the end plugs into the grey car-side connector.
I know the other one is the 194 wedge for the amber side marker.
Thanks!
sleey0 is offline   Reply With Quote
Old 09-11-2010, 07:52 AM   #78
fnkngrv
fnkngrv's Avatar
^ are you talking about the DRL bulb?
Old 09-11-2010, 02:19 PM   #79
sleey0
Is that what it is? I'm not so sure.
I thought the DRL's were bascially the H4 on during the day.
I have my DRL's disconnected and the light still comes on.
Anyway, if it is that, what kind of bulb is it?
Old 10-04-2010, 01:39 AM   #80
pspeezy
Drives: 09 Yaris Sedan
im assuming these sizes are not correct for an 09 yaris.....or are they?
pspeezy is offline   Reply With Quote
Old 10-04-2010, 01:42 AM   #81
chrisj
Hooch Brewer-Shine Sipper
chrisj's Avatar
Drives: 2009 5-dr LB
Here is more info.
Get size 194 for the map lights and license plate.
Get the 36mm festoon for the trunk (checked an earlier post for that).
Get the 32mm for the dome.
chrisj is offline   Reply With Quote
Old 10-04-2010, 01:44 AM   #82
pspeezy
Originally Posted by chrisj View Post
Here is more info.
chris im pretty sure i would be lost without you hahahahahaha
thank you once more.
Old 10-04-2010, 01:45 AM   #83
chrisj
chrisj's Avatar
Glad to help where I can. You have lots of options when choosing bulbs, such as whether they put out light 360 degrees or 90 or 120. Up to you.
BTW, the 194 is the wedge type.
Old 10-04-2010, 01:48 AM   #84
pspeezy
yeah i was noticing that while looking on the site, what degrees did you go with?? cause yours came out real nice
Old 10-04-2010, 01:53 AM   #85
chrisj
chrisj's Avatar
Here is exactly what I got (except for the dome). I am looking at my invoice.
1 | 3710 High Power LED Festoon bulb | $ 14.95 |
Cool White 3710-CWHP6 7.00
2 | WLED-x5 LED Wide Angle LED bulb | $ 3.94 |
Cool White WLED-CW5 0.95
1 | WLED-x-x LED bulb | $ 1.39 |
120 Degree Cool White WLED-W-x 0.60
First one was the cargo area
Second ones were the map lights
Third one was the license plate light
Old 10-04-2010, 01:59 AM   #86
chrisj
chrisj's Avatar
My dome was this one:
http://cgi.ebay.com/ebaymotors/Light...Q5fAccessories
Old 10-04-2010, 02:20 AM   #87
pspeezy
ive got everything in my shopping cart, except for a dome light, i cant seem to find 32mm off that website?!
edit: would it be bad if i got a 30 mm instead?
Old 02-13-2011, 10:59 PM   #88
tk1971
tk1971's Avatar
Quick question. On the Hatchback, is the high mount brake light assembly (aka 3rd brake light) an LED assembly or is it an array of filament bulbs. Looks small, so I'm guessing LED. Just confirming.
Thanks.
tk1971 is offline   Reply With Quote
Old 02-19-2011, 05:13 PM   #89
Trubin
Trubin's Avatar
Drives: 2009 Toyota Yaris Hatchback
Trubin is offline   Reply With Quote
Old 02-23-2011, 10:58 PM   #90
kurisu
Drives: 2009 Yaris
Originally Posted by Trubin View Post
Is that 9003CB Cool Blue Halogen? Looks nice, how much did you get it?
kurisu is offline   Reply With Quote
Tutorial : Speaker Changing, Headlight Painting, Center Control Colour,Panel Removal hasher22 DIY / Maintenance / Service 88 03-06-2014 06:40 AM
Bulb sizes for all Yaris Models DJ_SpaRky Cosmetic Modifications (Exterior/Interior) 16 07-22-2009 10:23 PM
Accessory Bulb Types, anyone know? Ayka Cosmetic Modifications (Exterior/Interior) 135 04-29-2007 08:33 AM
