Old 03-02-2011, 06:30 AM   #1081
TOLMACH
Drives: soarer
https://www.madisound.com/store/prod...oducts_id=8234
Old 03-02-2011, 07:29 AM   #1082
derickveliz2
derickveliz2's Avatar
Drives: Yaris Sedan "S"
Thumbs up
Originally Posted by TOLMACH View Post
Not bad for $90+ a pair
requieres a vented box of 0.40 cuft with a 2" diameter vent by 7" long, for an F3 of 44Hz.
D.
CLA 250, 4MATIC
Old 03-02-2011, 07:33 AM   #1083
derickveliz2
Question
The heater core is behing the glove box as I recall. It's a challenge...need to take off the dash pad though, just to see the real estate we'd be working with.
I wasn't thinking going that deep, I'm considering 6 or 8 inches of firewall/floor, I'll try to sketch some thing out, do you have the physical dimensions of the I6SW, looks pretty massive!
D.
CLA 250, 4MATIC
Old 03-02-2011, 02:58 PM   #1084
derickveliz2
Exclamation
Ok, this is only a sketch (it's a cross section parallel to the car, right in the middle of the passenger's seat) these are my thoughts in paper and it's only an idea, I took some liberal dimensions and I don't know the specs of the I6SW so I'm assuming 7 inches in diameter and about 6 inches depth.
I know I could shrink every thing a little bit more, and/or change the angle of the mini-woofers.
I thought it this way because my wife usually takes her shoes off and she could rest her feet on top, well not in winter until its warm and cozy, but that is once in a while, 99% of the time I drive alone. I'm going to have to make a mock up and sit my self to get a feeling on how bad the space would be!
D.
CLA 250, 4MATIC
Old 03-03-2011, 12:59 AM   #1085
sqcomp
Roadrunner Jr.
sqcomp's Avatar
E-mail to you D. There are possibilities here. it's just about how much we want to put into it. The nice thing about these Imagines is the reverse surround. That allows for excursion without having to worry about the surround rubbing.
― Thomas Paine
Old 03-03-2011, 03:18 PM   #1086
derickveliz2
Arrow
I knew that there was a "why" behind the HAT driver's design! I think I asked before, but I kind of knew the answer!
Looking into the glove box area too.
D.
CLA 250, 4MATIC
Old 03-03-2011, 11:56 PM   #1087
derickveliz2
D.
Not a lot of space, the glove box as is, it's about 0.15 cuft, using all the space of the glove box I'm guessing about 0.25 cuft.
I'm still on the idea under the glove box/fire wall....
D.
CLA 250, 4MATIC
Old 03-04-2011, 06:49 AM   #1088
sickpuppy1
Drives: 2010 Yaris Sedan
I kinda looked around up there too when the idea came up. Decided I needed my glove compartment more and stuck with the trunk placement. I really like the idea of having it up front. But unless I glassed off the entire bottom access to the dash, I couldnt find a good way to get space for a cabinet.
Old 03-04-2011, 08:44 AM   #1089
derickveliz2
Thumbs up
I know what you mean...
A few days with the sub up front and it's not going back to the trunk!
I hope the idea of the I6SW works even if it's under the glove compartment in a removable enclosure.
D.
CLA 250, 4MATIC
Old 03-04-2011, 10:06 AM   #1090
Maitre_Te_Te
Drives: Yaris 08
LOLLL wow... how many RMS whatt do you have in your car?
Maitre_Te_Te is offline   Reply With Quote
Old 03-04-2011, 11:15 AM   #1091
derickveliz2
Wink
Not a lot but just enough for SQ
Tweeters.....75w
Mids............75w
Mid-Bass......100w 200w soon!
Sub-W.........500w
Mid-Bass upgrade to 200w soon!
D.
CLA 250, 4MATIC
Old 03-04-2011, 02:26 PM   #1092
sqcomp
Roadrunner Jr.
sqcomp's Avatar
We can probably extend the top of the enclosure you have illustrated UP to just under the AC/Heater unit... That may give you the ability to flatten the front of the enclosure out a little.
You may also want to think about making the subs fire onto the firewall area and have an inch or two of space from the firewall and the bottom of the woofer. Still having the woofers in a sealed enclosure of course. Think of it liek a downfiring setup, except aimed to the firewall instead of down.
― Thomas Paine
Old 03-04-2011, 02:56 PM   #1093
derickveliz2
Thumbs up
I'm looking for dimensions, then I could mock up in place. How much bigger than the L6s are the I6SW?
D.
CLA 250, 4MATIC
Old 03-04-2011, 05:28 PM   #1094
Shinare
Bronze bombshell yaris
Shinare's Avatar
Drives: 09 Yaris HB 3door
...my wife usually takes her shoes off and she could rest her feet on top...
D.
Not if she's ticklish! heh
Old 03-04-2011, 11:46 PM   #1095
derickveliz2
Wink
I'm going to call it... "Foot Massage" as a sales point... LOL
I'm plying with the L6s ring's in the area below the glove compartment, I'll shoot some pictures tomorrow.
D.
CLA 250, 4MATIC
Old 03-05-2011, 12:40 AM   #1096
sqcomp
Roadrunner Jr.
sqcomp's Avatar
Scott's still working on getting the official specs into .PDF...
― Thomas Paine
Old 03-05-2011, 12:46 AM   #1097
derickveliz2
Talking
Awesome!
Sqcomp... did you just change your avatar?
D.
CLA 250, 4MATIC
Old 03-05-2011, 12:46 AM   #1098
derickveliz2
I just couldn't stop thinking about it, here are some pictures with the L6 rings, they are about 8" in diameter. I sit down for a minute to see how bad it is, It's ok as long as you don't want to stretch your legs.
Now I have to calculate how much space is behind there, and take in consideration the thickness of the MDF if any. May have to glass the area and fill it up and check the internal volume.
D.
CLA 250, 4MATIC
