Old 03-15-2011, 01:11 PM   #1
limey163
limey163's Avatar
Drives: 2010 Black 2D Hatch Yaris
Check Engine and Traction Control Light On
Hey Yaris community,
I just recently installed an aftermarket air filter into my Yaris. It runs wonderful but I have a little issue; the traction control and check engine lights are on. The car runs fine (only issue is I cant depress the gas too far down, if i do it seems as if the car isnt receiving the throttle).
I've checked for holes or cracks in my installation but everything seems sealed, I even electrical taped it to be sure.
Note: I am using the factor air intake hose with the breather attached. I tried connecting an aftermarket breather but after starting the car, it rattles and the entire engine shakes, then it shuts off. Any help is appreciated!
limey163 is offline   Reply With Quote
Old 03-15-2011, 03:17 PM   #2
yaris2010RS
yaris2010RS's Avatar
so u have the entire factory airbox? with the MAF sensor left in place and plugged in?
Old 03-15-2011, 03:25 PM   #3
limey163
limey163's Avatar
I took the factory airbox out, only thing I left was the hose because the car needs a direct breathing source apparently.
Old 03-15-2011, 03:31 PM   #4
yaris2010RS
lol and lol......
i need to have the MAF sensor. not overly difficult to make a mounting bracket for it on a custom intake but it has to be there. that is the reason for your issue.
as for a direct breathing source? what does that mean?
Old 03-15-2011, 03:34 PM   #5
limey163
limey163's Avatar
Oh no, the MAF sensor is still there man, the new filter has a slot for it. All i removed was the clunky plastic box.
Old 03-15-2011, 03:35 PM   #6
yaris2010RS
oh. and its plugged into the harness? (just making sure)
Old 03-15-2011, 03:39 PM   #7
limey163
limey163's Avatar
Yep. Was the first thing I checked.
Old 03-15-2011, 03:46 PM   #8
yaris2010RS
odd..... did u touch anything else? lol do u have a pic of ur setup? its hard for me to visualize whats going on.
have u tried resetting ECU after u put it together? (unplug battery for a few mins and re hook it up
Old 03-15-2011, 03:55 PM   #9
limey163
limey163's Avatar
I'll try to get a pic to you (wont be till later tonight). I haven't tried the reset, will do that before leaving work. I didn't come near to disconnecting anything else. Thanks in advance.
Old 03-15-2011, 04:01 PM   #10
yaris2010RS
np, i could see if u ran the car without the MAF hooked up the car would go into basically a "safe" mode cycle and throw a code (display check engine and trac) but one would think when its hooked up again it would at least get out of the safe cycle.
unplug the battery and while the battery is unplugged also:
unplug the MAF
then reconnect the MAF
then plug the battery back in.
**this will ensure u leave the battery unplugged for enough time (i believe it needs at least 90 seconds) and it will make sure the MAF was propperly plugged in.
Old 03-15-2011, 04:01 PM   #11
yaris2010RS
and Welcome to YW!
Old 03-15-2011, 05:18 PM   #12
limey163
limey163's Avatar
Will try that and let you know, thanks for the welcome :).
Old 03-16-2011, 10:35 AM   #13
limey163
limey163's Avatar
The site isn't allowing me to track my sent messages YarisRS, so i'm going to post it here and you might also have a duplicate message. Here are some pictures I took earlier on break:
http://img10.imageshack.us/g/photo031610063.jpg/
Let me know what you think.
Old 03-16-2011, 11:09 AM   #14
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
disconnect battery for 5-10 minutes should fix it.
Old 03-16-2011, 11:33 AM   #15
limey163
limey163's Avatar
Tried that yesterday and it did, but after 40 or so minutes of driving, it came back on again.
Old 03-16-2011, 11:30 PM   #16
yaris2010RS
^ the MAF is getting a messed up reading. its off but not by a lot or not on a constant basis
Old 03-17-2011, 12:32 PM   #17
Vinceb
Drives: 2008 5 Speed Sedan
no chance this new filter was one that you have to oil, and by chance you oiled too much and it covered the MAF sensor is there? otherwise maybe the MAF got bumped when swapping and needs to be replaced?
Vinceb is offline   Reply With Quote
Old 03-17-2011, 01:57 PM   #18
Lil Abner
Drives: 2009 3dr LB Manual
Can you put the factory air box back in and see what happens? All the electrical tape has me curious. Why is all the tape on there? And yes, the MAF could be dirty from a over-oiled filter. Or maybe that MAF pipe is the wrong diameter. Compare the diameter to the stock tube. They need to be the same! If it's bigger, the MAF will not read correctly.
The Yaris Performance Primer eTiMaGo Performance Modifications 31 10-20-2025 09:08 AM
Newly refreshed 2011 Toyota Corolla Kal-El Off-topic / Other Cars / Everything else Discussions 23 11-27-2010 12:57 PM
Yaris Engine Swaps!!! Duckywitbigfeetz Performance Modifications 88 06-24-2009 02:57 AM
