Old 03-24-2011, 02:48 PM   #91
Jason@SportsCar
^ simple and a clever solution! -- but not many would do without their speedo on a street car.
Yeah... Our dash uses GPS speed. But if you just want to do a top end run (on a closed course) it is a temporary solution - although if you unplug it for your top end run you better have another way to verify speed.
Old 03-24-2011, 03:14 PM   #92
racerb
Originally Posted by Bluevitz-rs View Post
simply cut the wire going from the speedo to the ECU and you're free to speed away and you still have your working speedo. You will have a CEL though.
This is the exact same solution to the limiter issue on the early Celicas, in fact the wire is marked SPD on the ECU main plug!
racerb
racerb
'86 Celica GT
'87 Celica GT-S
'98 Rav4L
'01 Tundra SR5
Old 03-24-2011, 03:26 PM   #93
I also made one for the rev limiter, but am afraid to test it on a live engine.
If you set the rev limit to LESS than stock, you should be fine to test it.
Old 03-24-2011, 03:42 PM   #94
Astroman
Modded Moderator
Astroman's Avatar
That might be cool if you could turn it on and off with a toggle switch.
Old 03-24-2011, 04:01 PM   #95
What is does is send a modified tach signal that indicates that the engine is spinning at a different speed than it really is. I am afraid to test it in either direction (telling it is is spinning faster or slower).
Old 03-24-2011, 04:09 PM   #96
^ Gotcha. Do it anyway.
just kidding
Old 03-24-2011, 05:10 PM   #97
just kidding
I really need another Crashy to be able to do potentially catastrophic testing on.
Old 03-24-2011, 05:26 PM   #98
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
I would like to have the limiter disabled only for those times that I am taking it for official timeslips, etc once I have my turbo installed.
Old 03-24-2011, 09:27 PM   #99
racerb
At what RPM does the stock rev limiter kick in? If it's anything like most FI factory systems, there is about a 200-500 RPM window above the point where it kicks in to safely rev the engine. Back in my Auto-X days, I raced a 1989 Civic Si, it's factory rev limiter kicked in around 7,000 RPM but the engine would free rev to around 7,200-7,400 and come back for more abuse!!
racerb
racerb
'86 Celica GT
'87 Celica GT-S
'98 Rav4L
'01 Tundra SR5
Just got my BB Liftback 5 speed festrca New England 19 06-02-2007 05:06 PM
blazing blue 5 speed carp73 NY / NJ/ CT / PA 2 11-09-2006 08:12 PM
top speed? cptsenestpc General Yaris / Vitz Discussion 33 11-01-2006 04:21 PM
Free gas for any vehicle. ketel0ne General Yaris / Vitz Discussion 4 09-19-2006 08:07 AM
[Detail] [as to make ] Auto Laudering Sérgio Barros Wash, Wax, Detailing, Exterior Repairs 4 08-22-2006 03:56 AM
