Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Second Generation Toyota Yaris Main Rooms > Regional Forums > Middle East
Old 03-28-2011, 02:42 AM   #1387
kiel12
kiel12's Avatar
Drives: 2011 toyota yaris Y
Originally Posted by EjDaPogi View Post
kung gusto mo lakarin natin mamayang gabi. wala naman akong commitment eh.
naku negative ako mamayang gabi pre..me sakit pa si kumander eh kaya aalagaan ko muna para gumaling kagad, pero mamayang lunch time lalabas ako me kikitain akong customer namin tapos punta ako dun sa mga bilihan ng accessories para maitanong kuna yung relay kung magkano.
kiel12 is offline   Reply With Quote
Old 03-28-2011, 02:44 AM   #1388
EjDaPogi
EjDaPogi's Avatar
Drives: 2008 Yaris Fleet (SilverWings)
Originally Posted by fgorospe76 View Post
Sama ako dyan bro, kahit sa Friday DIYsession tyo. I-sked na din daw ung kay Zsa Zsa sa pagkabit ng LED nya
@frankie, tell zsazsa to buy shawarma para may foods tayo sa DIY.
EjDaPogi is offline   Reply With Quote
Old 03-28-2011, 02:47 AM   #1389
fgorospe76
"i R i S H"
fgorospe76's Avatar
Drives: Toyota Yaris 2010
Madam Zsa Zsa paki-suyo daw magdala ka daw ng pizza sa Friday para may food tyo sa DIY session..Thanks!
fgorospe76 is offline   Reply With Quote
Old 03-28-2011, 02:49 AM   #1390
syntax
syntax's Avatar
shawarma naging pizza weheheheheheh
Old 03-28-2011, 02:50 AM   #1391
fgorospe76
"i R i S H"
fgorospe76's Avatar
typo error ako bro wehehehe
Old 03-28-2011, 02:57 AM   #1392
EjDaPogi
EjDaPogi's Avatar
intentional typo!
Old 03-28-2011, 03:18 AM   #1393
syntax
syntax's Avatar
Old 03-28-2011, 03:40 AM   #1394
rye7jen
rye7jen's Avatar
Drives: 2nz-fe '10
@duke, question, hindi na ba sila nag-lagay ng inline fuse para sa relay? in-between ng relay at battery?
rye7jen is offline   Reply With Quote
Old 03-28-2011, 04:32 AM   #1395
rosco
rosco's Avatar
Drives: YaRis ka!--Y?2011
Originally Posted by duke_afterdeath View Post
tama po si kiel relay assembled with wires nga ung sakin set na kulay dilaw un na may mga wires sa loob, if may makukuha kayong 45sr good price na un.. madali lang ikabit kaya lang ako napamahal sa labor gawa nga ng foglight ko nagpalit ng wire then kinumpuni pati ung damage na fuse pero kung ung H4 relay set lang for sure mura lang labor..
steps sa pagkabit ng H4 relay:
1. ilatag muna ang wires.
Attachment 40722
2. ikabit ang unang socket (male socket) ng H4 relay sa original (female) socket ng headlight (sa kanang headlight kung nakaharap sa kotse).
Attachment 40723
3. ikabit ang pangalawang socket (female) ng H4 relay sa bulb ng headlight (sa kanang headlight kung nakaharap sa kotse).
Attachment 40724
4. tanggalin ang original socket (female) sa bulb (headlight sa kaliwa kung nakaharap sa kotse) at ikabit ang pangatlong socket (female) ng H4 relay sa bulb ng headlight (sa side na ito di na kakailanganin ang original socket itali na lang para wag aalog-alog )
Attachment 40725
5. ikabit ang ground sa kaha ng kotse (magkabilang socket kulay itim na wire).
Attachment 40726
6. ikabit ang power wire (dalawang wire kulay pula) sa battery.
Attachment 40727
sana po makatulong....
bravo!
ganyan din ginawa ni fort..itinago nya yung wire(dilaw sayo) sa loob ng front grill..para di masyado ....dami nakalabas daw...
rosco is offline   Reply With Quote
Old 03-28-2011, 04:39 AM   #1396
rickyml
rickyml's Avatar
Drives: Yaris 2008
Originally Posted by rosco View Post
bravo!
tanong ko lang po, bakit nagpapakahirap pa kayo sa relay na yan, meron naman pong mas mababang watts... like mine. ano po ba pinagkaiba? parehas din nman ang liwanag.
Yaris X: The Largest Most Organized Pinoy Yaris Owners Group In The Middle East (Eastern Region Chapter)
rickyml is offline   Reply With Quote
Old 03-28-2011, 04:39 AM   #1397
EjDaPogi
EjDaPogi's Avatar
no problem tol. get well soon to mrs. pascual.
timbre mo na lang kung positive!
Old 03-28-2011, 04:47 AM   #1398
duke_afterdeath
duke_afterdeath's Avatar
Drives: 2008 Yaris Sedan
tol no need na for the fuse, as you can see ginamit natin sa installation ung unang original socket na naka install naman sa fuse at switches sa fuse box.. at dahil may relay nga di na po need magpalit ng higher fuse.. actually diko naitanong ito sa electrician paki correct na din po mga kayaris then ask ko din yung gumawa if tama nga yung pananaw ko, hehe..
tol mas mataas ang wattage mas maliwanag lalo at mas malakas kumain ng load (kuryente) kaya advice nga po ng electrician ang relay para i-handle nya ang load... same lang po sa bombilya natin yan sa bahay 100 watts is brighter than 50 watts
Yaris X: The Largest Most Organized Pinoy Yaris Owners Group In The Middle East (Central Region Chapter)
Disclaimer: Not Connected to Toyota A.Lathif Jameel ME In Any Way
If everything seems under control, you`re just not going fast enough...
duke_afterdeath is offline   Reply With Quote
Old 03-28-2011, 04:49 AM   #1399
rickyml
rickyml's Avatar
Drives: Yaris 2008
so, ok lng po ba yung sa akin na 380watts? kasi so far wala naman akong naaamoy na sunog... or anything unusual sa makita, fuse and wiring...
Old 03-28-2011, 04:51 AM   #1400
EjDaPogi
EjDaPogi's Avatar
lufet mo talaga duke_afterSMOKE
Old 03-28-2011, 05:01 AM   #1401
duke_afterdeath
tol advice ng kabayan electrician yung design po ng wirings ng headlight at foglight ng yaris natin ay di angkop sa mas mataas ng wattage (OEM lang daw talaga ang pwede, unless gamitan nga ng relay or ballast for HID naman) marami na din daw sya ginawa na nasunog ang fuse wires at hindi lang ito sa toyota or yaris may mga ginawa na din syang ibang kotse na same problem,,, gaya nga ng nabanggit ni kapatid na rosco sa safe side na tayo... pero cyempre nasayo ang desisyon tol sakin lang po base sa experience ko mas lalaki ang problema at lalaki pa ang gastos
Old 03-28-2011, 05:03 AM   #1402
duke_afterdeath
busettt!!!
Old 03-28-2011, 05:12 AM   #1403
EjDaPogi
EjDaPogi's Avatar
mabuhay
well said. mabuhay si duke_smoke
Old 03-28-2011, 05:12 AM   #1404
kiel12
kiel12's Avatar
+1
