Drives: 2002 Vitz Automatic Join Date: Feb 2007
I have an 2002 Automatic Vitz and it is reving high when starting. I believe the automatic choke is stuck in the on position. Can anyone tell me where the automatic choke is located and how to adjust it.
![]() ![]() Drives: 2007 Yaris Liftback BBP Join Date: Oct 2006
Does the idle keep going up and down after it starts to warm up a bit? Toyota used a valve in the past on some of the vehicles that would cause this problem, It is linked into the cooling system.
"I am un chien andalusia" - Black Francis |
![]() ![]() ![]() ![]() ![]() Drives: 06 3-dr auto RS Join Date: Jan 2006
I believe that there is a good chance that the car's computer is, among its many functions, doing the duties of a choke. You may be experiencing a problem not related to a choke in the traditional sense.
Wish you can solve the problem soon! |
![]() ![]() ![]() Drives: 07 Civic Si Coupe(Black Pearl) Join Date: May 2006
Choke? I think those went out of style round the same time as billy idol
Yea sounds like a computer problem, is the check engine light on? First thing i'd do is scan the comp for codes. |
It's normal for it to rev high at first, and gradually settle down, just part of the automated warming up process
![]() ![]() ![]() Drives: 2007 Toyota Yaris sedan Join Date: Aug 2006
How do you scan codes? I want to know how.
How high is it revving?
You can buy a scangauge @ scangauge.com, awesome product or go a mechanic or something. |
most mechanics charge you.
autozone and the like will scan for free :) |
![]() Drives: toyota 07 yaris Join Date: Feb 2007
That's what I like about about autozone as they give you a free scan. You can use the money you have saved for the services of mechanics in case you need one.
________________ Toyota 07 Yaris - Get the Toyota 07 Yaris Catalog by Toyota Motors |
Resident Redneck
Drives: 07 Polar White Yaris Sedan 5M Join Date: Jul 2006
If there isn't a check engine light on, then a scan tool (like the ones at AutoZone) will not help you.
Besides, guys, I don't think there are any AutoZones in Ireland. If it doesn't go away after the vehicle is warm, then it sounds like an idle air control valve to me. I see them everyday. It may just need to be cleaned out- I'm not sure if yours is on top of or under the intake manifold- wherever it is, pull it out, spray carb cleaner through it until the carbon buildup is gone, and re-install. If the problem persists, contact your Toyota dealer. They, and only they, have a new computer (just released to dealerships) that can pull a history and health check- it pulls all codes and diagnostic information stored in your ECU. At that point they can make a determination as to what is wrong- even if there is not a check engine light on.
My other rides: 2003 Honda Civic LX Coupe 5M- S/C K24 w/ LSD coming soon! 1999 Honda Civic EX Coupe 5M w/ B18 powaa 1985 Toyota Celica GTS Coupe 5M- track whip http://www.importlounge.com |
| 5spd vs automatic | m-arco | General Yaris / Vitz Discussion | 16 | 12-14-2006 05:32 PM |
| Is that bad for automatic transmission? | hans_fh | General Yaris / Vitz Discussion | 9 | 11-20-2006 07:25 AM |
| Automatic LB w/CP in FL?? | Placebo | New YARIS Purchase Forum | 7 | 10-29-2006 10:50 PM |
| Manual vs. Automatic ?? | YarisBlazer | General Yaris / Vitz Discussion | 12 | 08-13-2006 07:14 PM |
| Shift Knob for automatic | noodles009 | Cosmetic Modifications (Exterior/Interior) | 13 | 07-28-2006 05:18 PM |
