Old 10-01-2009, 05:23 PM   #55
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
Originally Posted by birdman View Post
A cut out dot would obscure the light in a way that may make it hard to see when the brights are mistakenly on during the day.
Oncoming drivers will be glad to let you know you have your brights on.
Old 10-01-2009, 05:53 PM   #56
birdman
Drives: '08 Blazing Blue Yaris LB
And how!
birdman is offline   Reply With Quote
Old 10-01-2009, 06:10 PM   #57
birdman
Since this query is duplicated further down the DIY list, is it possible to remove this one and leave the other?
Old 10-02-2009, 04:08 AM   #58
birdman
Apparently not.
Old 10-02-2009, 02:28 PM   #59
Astroman
Modded Moderator
Astroman's Avatar
I for one can tell when I'm using the high beams. That little light doesn't do anything for me but distract my vision. Besides, were not really talking about blocking the light out, and driving around with high beams on all the time. If someone comes at me with their high beams on, I just flash them. 9/10 this takes care of it.
Old 10-02-2009, 08:53 PM   #60
birdman
People are so stressed out these days the less they're provoked the better.
Old 10-17-2009, 01:31 AM   #61
birdman
Thanks to Scott I have successfully added the resister and have a lighter blue high beam indicator light. Still easy to see and much gentler on my tired old eyes. A very easy to do fix.
Old 10-18-2009, 10:40 PM   #62
andru47
andru47's Avatar
Drives: 2009 Yaris 3DR LB
Send a message via AIM to andru47
Solution, tint the gauge cluster...
My Yaris: The Azure
andru47 is offline   Reply With Quote
Old 05-05-2011, 01:38 PM   #63
BIGTAZ351
147K-Blue / 24K-Yellow
BIGTAZ351's Avatar
Drives: 2010 Ylw 3dr. AT(Blue-Wife's)
Old thread, I know, but I need to know how to get the first piece of dash trim off, (2010 3dr) without breaking something! I tried searching but didn't find anything of any use. Even the better half said last night, "You gotta do something about that BLUE LIGHT!" I have black tape on the lens since I had 130 miles on the car, but it is so bright it lights up the trim piece that needs to come off, that I see it in the windshield.
You guys are great, Thanks in advance!
P.S. I loved the red indicator in the '71 Custom 500, even the green arrows were not "blinders". Up until 7 years ago I drove a '71 as a daily car, I like the mpgs of the yaris.
All Weather Package, Power Package, Cruise, WeatherTech Floor Mats. Altimax Arctic Winter Tires.
Repair List:
1 new blower motor, making funny noise. @ 91K (Water pump @ 120K)
Mod List:
1. Black tape on most of the annoying blue high beam light behind the lens. (thank you CTScott)
BIGTAZ351 is offline   Reply With Quote
Old 05-05-2011, 02:03 PM   #64
You have to remove the two vertical pieces along sides of the AC controls first. Grab the bottom corner by the storage pockets and pull out to get them started. Then, pull straight out at the top. Next, remove the speedometer trim by pulling it straight back. It is easiest to loosen the center of the top of it first and then work down to the flat area. Be careful of the flat tabs on the radio trim side of the flat area. If you have trouble pulling them out of the radio trim, then you can remove the radio trim with the speedo trim by pulling it straight out as well.
Old 05-05-2011, 02:32 PM   #65
BIGTAZ351
BIGTAZ351's Avatar
For some odd reason I knew it'd be you, Scott to reply first, I consider you an expert in the D.I.Y. Yaris World, Thank you....
I absolutely Love "Crashy" BTW.
Repair List:
Mod List:
Old 09-17-2012, 10:44 PM   #66
VitzNCP91
Drives: 2007 Yaris
Sorry to reopen, but is there a section where it can tell how to remove the speedomter's needle. Any info will be greatly appreciated.
VitzNCP91 is offline   Reply With Quote
Old 09-17-2012, 11:14 PM   #67
The needle is just pressed onto the servo that drives it, so you carefully pull it off. I suggest making a small mark across the clear to grey area at the base of the needle, so you can align it correctly when you put it back on. When you do press it back on, hold the back of the servo assembly to avoid damaging the tiny plastic gears inside, while pressing the needle assembly back on.
Old 09-27-2012, 01:55 PM   #68
chaditotx
Drives: 2007 3dr hb 5sp
Originally Posted by scape View Post
i really dislike blue LED indicator lights that show up on everything these days, it truly is annoying, and the blue itself is way too bright; as for the dashboard, i think it makes sense to have one as you don't want to be driving around with your brights on all night-- that's not fair to others, so you should be reminded that it is on; even if it's a tad annoying. so to sum up, I bring nothing productive to the OP, hah :D
you could always crack open the dash and just replace the LED, or add a piece of painters tape onto the front for long drives
I concur.. .don't like the blue. My 71 Ford truck had a red high beam indicator. Every time I'd tap the floor switch for brights I'd think I had low oil pressure though.... bummer.
chaditotx is offline   Reply With Quote
F/S Blue Stitched Leather Shift Boot. 1NZYaris1 Items for Sale by private party 9 05-07-2009 12:59 AM
Bayou Blue paint code andru47 General Yaris / Vitz Discussion 7 01-03-2009 05:19 PM
Blue Film over gauges Jeff1 DIY / Maintenance / Service 10 10-21-2008 04:01 PM
Black or Blue CrashRescueFF New YARIS Purchase Forum 18 07-24-2007 08:21 PM
Nautical Blue Metallic YotaYarisUSA General Yaris / Vitz Discussion 0 04-02-2006 08:09 PM
