i want to know can i connect amp with it ??? i dunno where to plug amp leads :/
if yes where i can plug it :P here are some pictures plz help me :P |
Of all of the Toyota documents that I have on audio, none shows the pinout of all of those connectors. The bottom row, except for the center, is shown in the image below. In a worst case, you can use an amp that takes high level inputs.
Naomi which connectors actually go into the Radio ? Take a picture of them. Pretty sure it's the CN500 pin view. Ctscott is there a harness to where you wouldn't have to splice into the factory wire harness, maybe one that flips the harness around and has leads coming out of the harness.
You're going to need a Line Output Converter (Hi-Lo Adapter)(LOC) Which will require you to cut into the Rear 6x9 speakers, and you'll need to run a remote wire, which will come off the Radio Ignition. I'd check if they have another wire harness that will help you not have too cut into the radio harness, but if you must. Radio Ignition- For the amp remote wire. LR-For LOC RR-For Loc
![]() ![]() Audio is under Construction Kenwood KDC-X794 Hifonics Zeus ZXI6.5C 6.5-Inch 2-Way Component Speaker System - AUTOTEK ATX65CX 6.5-Inch Hifonics BXi 1210D - Crunch PowerZone P1400.4 (2)12 inch Kicker CVR's - 0 gauge from battery to Distribution block - 4 Gauge Power/Grounds to amps - Duralast Yellow Top - Big 3 |
hope i got the best shots :)
Green+Red running thru amp = REMO wire, Grey Wires with RED+WHITE endx = LINE INPUT running thru AMp need to be plugged in the HU...but dunno which One is used for both respectively... *(One RED WIRE is for the battery +ve and One RED WIRE is Ground -VE)* sorry for my bad english.. |
What gauge wire did you use for your Amp ? I'm looking at your wiring, looks different, imma look at it some more later on.
Get some connectors buddy, make your life a whole lot easier . ![]()
i actually dont remember what's the gauge...:/
yup i'll :) once i get to know which switch is used for RCA output for amp in head unit than i'll install connectors and just enjoy boom chika wawow :P can u notify which empty switch is used for RCA output in this head unit :/ im confused |
Need something like this (LOC) Line output converter. It connects to your Rear speakers and has the connects for your RCA's .
hey i got one from pioneer :)
i've connected to the speaker wires :P thnx for all ur guidance :) but um some of my fuse died hehe :P can u guide me which one to check ?? under the drawer dash or or the one in the engine bay area :P |
Do your dome lights work ? Radio ? Door locks ? What works and what doesn't ? best thing to do is get a Digital multi meter or Light tester and check your fuses. Light tester is going to be the easiest way, you touch the lead to the fuse and if it lights the fuse is good, thing is you need to touch both sides of the fuse.
thing is when i connected rem wire :p some of the fuse died :p my friend checked it,he said the parking lite are getting sparked somewhere that's why the fuse are dying :P
later, my retract mirrors died,headlights gone,interior lites gone,brake pedal shifter for gear gone,radio gone,brake lights and camera too :P than i replaced some of the 10 amperre fuses with good ones, now everything works except the parking lites,and radio lites,and rear camera :P and later i got it checked from a auto electrician he said i'll charge you 1000 bucks its around 12$ US. though i asked him whats the prob atleast lemme know why it is killing my fuses he said i won't tell you i'll fix you up and just charge you 1000 bucks :O i've that light tester :D and multi meter too :p i want to know what would be the fault In ur opinion :/ where should i take the start...i dont want to give my money to that bad guy !!! |
Did you check the fuses under the hood ?
Yup i did :)
all fixed now :D just changed some faulty fuses with new ones and now im good to go Yays :] everything is now perfectly working i'm happy :) thanks for your help and guidance |
Cool deal man, take pics of the system.
#14 |
i'll soon upload some of the pics and video too :) now i just want to change my existing lasani enclosure to fiber glass enclosure with some l.e.d's on it :P i think it will look cool eh B")
#15 |
Drives: Toyota Vitz 2004 Join Date: Aug 2007
@nomi--------hey that black wire coming out from the blue connector..is it for adding auxiliary input..cuz i want to add one to my nd3t-w54 ...can u please help as which connectors and wires are required ?
#16 | |
auxiliary or not..sorry bro it wasn't mentioned there...but i think it is what u said :) |
| Head Unit Install | mannon | In Car Entertainment + Electronics (audio / video / alarm) | 9 | 08-14-2009 01:18 AM |
| Feeler: Pioneer AVH-6850DVD 2-DIN head unit + extras | eTiMaGo | Items for Sale by private party | 19 | 08-07-2009 09:49 AM |
| High pitched whine using stock head unit / aux input? | IsLNdbOi | In Car Entertainment + Electronics (audio / video / alarm) | 8 | 02-02-2007 12:49 PM |
| Stock Head Unit from '07 Sedan | Venom | Items for Sale by private party | 5 | 01-19-2007 08:27 PM |
| installed head unit... | punch | In Car Entertainment + Electronics (audio / video / alarm) | 16 | 06-29-2006 12:06 AM |
