![]() Drives: 2010 Liftback Join Date: Apr 2011
tire pressure sensors
I remember reading on here someone saying that the tire pressure sensors used on the factory steel wheels are different than the ones used with the factory alloy wheels? Is this true?
NO.
![]() Drives: 2011 3Dr Hatch Join Date: Apr 2011
Can they be taken off factory steel wheels and put on aftermarket wheels?
2ZR swap. DO IT! Ask how!
From what I understand, the Yaris' TPS isn't in the tire. Check out the details here: http://en.wikipedia.org/wiki/Tire-pr...ystem#Indirect
![]() ![]() ![]() ![]() Drives: 3-door hatch Join Date: Oct 2010
The (2011) Yaris TPMS is part of the valve stem so they are inside the tire. They can be moved from the steel wheels to alloy wheels. I had it done when I had my steelies replaced with the Scion 7-spokes on my Yaris.
#6 | |
i swapped my sensors off my steelies to my rota's. They fit fine.
The TPMS from your Toyota steel wheels can be swapped into just about every aftermarket wheel.
![]() ![]() ![]() Drives: '08 LB, '07 WRX Join Date: Jan 2009
All cars sold in the US now must have direct TP monitoring. That's what ford told us internally (after all, it was the explorer incidents with Firestone tires that started this whole thing)
| Tire pressure sensors | Yaris2go | Great Lakes | 4 | 03-19-2012 08:04 AM |
| NITROGEN GAS TIRE FILL: WORTH IT? | EjDaPogi | Middle East | 15 | 03-20-2011 02:06 AM |
| Tire Pressure Monitor Sensors....? | 09TRD | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 3 | 12-19-2008 09:25 PM |
| The Tire inflation debate... | Tankota | General Yaris / Vitz Discussion | 20 | 06-01-2006 07:09 PM |
