Old 05-20-2011, 03:27 PM   #1
landrym28
3,300+ at one point.. >:(
landrym28's Avatar
Drives: 2010 Hatchback RS
205/55/15 Tires and Fuel Efficiency
Good day folks,
Did a search for this with no results (for my specific tire size, anyway). I'm currently running 205/50/16's on my Yaris, and was thinking of down sizing (so to speak) to 205/55/15's. I've noticed a bit of a decrease in fuel efficiency in running 16's, would the gas mileage increase with the drop down to 15's? Would a wider tire affect FE?
Thanks,
Matt
Old 05-20-2011, 03:46 PM   #2
wheel/tire weight is the largest factor
i run lightweight 15's w/ 205's and get way better mileage than with my 14" alloys and 185 winter tires...
Old 05-20-2011, 03:55 PM   #3
landrym28
landrym28's Avatar
Yeah, I knew weight plays a huge factor for sure. I'm in the process of moving, so money I had set aside to get the car lowered and a sway bar, etc. is being put to that for the time being. Running 205/55/15's has a similar height than 205/50/16's (from what I can remember), so other than tire size/height, there shouldn't be a drastic change in wheel gap.
I also wanted 205 because running 185's makes me look like I'm driving my car on popsicle sticks..just too skinny of a tire for me.
-Matt
Old 05-22-2011, 01:05 PM   #4
205's are nice. i run 205-50-15's (though i HAVE run 55's) but my oem tire is 175-65-14 which is a bit shorter than what they use now
the 55's eat up wheel gap, thats for sure.
i would spend the extra on light wheels....its worth the money, trust me.
Old 05-22-2011, 02:44 PM   #5
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
It is mostly about the weight of the wheel. Although another thing is if the tire/wheel height is different the mileage you are going will be different than what the car is telling you.
I agree with lightweight wheels, they just make everything so much better.
Colin Chapman disciple
Old 05-23-2011, 07:58 AM   #6
landrym28
landrym28's Avatar
Thanks for the input! I might hold off for the time being, considering I just bought new tires for my 16's this past winter. I'm only getting about 100km/tank less than I was with my other 15s (It could be worse I guess). Right now, it might not be worth buying lightweight wheels & new tires. I would have to sit down and work out the costs. For the amount I would spend, it would probably take a few years worth of buying extra gas to offset that costs.
Considering the tires are new, I might just wait until they're worn down and need to be replaced, then switch to 15s then.
-Matt
Old 05-23-2011, 02:22 PM   #7
marlondog
Shut your fricken suck!!!
marlondog's Avatar
Drives: 07' liftback
I currently have 195/55/15s, but will change the out for 205/55's once the tires wear out. I've had them before, and there was a slight decrease in mileage compaired to the 185/60's. They fill in the wheel gaps, and give your car a "don't f with me" stance. They will also give your wheels some extra cushion and sidewall. 15's with little tires look pretty silly on our cars, so 205/55's or 195/55's will do the job.
marlondog is offline   Reply With Quote
Old 05-23-2011, 02:29 PM   #8
bah, my car looks fine w/ 205-50-15's....and i don't rub
"5 Driving Myths That Cost You Money" PETERPOOP Fuel Economy Forum 10 05-24-2011 10:20 PM
Goodyear Fuel Max Tires Sodium Duck Fuel Economy Forum 47 01-08-2010 11:26 AM
My review of hankook tires 205/55/15 on stock rims YarisSedan Wheels, Tires and Suspension Forum sponsored by The Tire Rack 0 09-30-2009 01:01 AM
