Old 05-24-2011, 08:11 AM   #1
henry33
Drives: yaris1.33
CANBUS alarm
does somebody install this kind of alarm ?
is it really plug and play with simple connector to plug and ready to use ?
thank you
henry33 is offline   Reply With Quote
Old 05-24-2011, 09:18 AM   #2
I don't know of anyone using one, but in theory it can work. From the CAN bus I can tell you if a door is open, if it has been unlocked with the key or remote, etc. So, all of the info is there, but if the device simply plugs into the OBD port, then disabling it is much quicker for a thief than for an alarm that is buried under the dash with wires connected all over the place.
Old 05-24-2011, 09:47 AM   #3
henry33
Drives: yaris1.33
is the obd and canbus the same ?
this should be installed under the dash not visible to anyone . it is basically the very same model as the non canbus only the harness is different.
Old 05-24-2011, 10:01 AM   #4
henry33
Drives: yaris1.33
scott do you know where the canbus is located in Yari
Old 05-24-2011, 10:47 AM   #5
The CAN bus is accessible at the OBD port. The violet wire in pin 6 is CANH and the white wire in pin 14 is CANL.
Old 05-24-2011, 11:24 AM   #6
BLH
Drives: 2007 Yaris Sedan
Just be real careful.
The CAN buss runs data between many of the electronic control modules in the car.
Mess it up and who knows what will happen.
http://www.etimago.com/yaris/repairmanual/CAN.pdf
BLH is offline   Reply With Quote
Old 05-24-2011, 11:30 AM   #7
It's actually very hard to mess it up with the robustness of the communication protocol. When you do (as I once did with a flakey transceiver IC), the ECM goes into limp mode and your warning lights make the cluster look like a christmas tree.
Old 05-24-2011, 01:53 PM   #8
BLH
Thanks for the information.
As an electronic technician. I maybe overly cautious. I have had too many parts emit magic smoke.
Old 05-24-2011, 02:01 PM   #9
As an electronic technician. I have seen some busses get smashed big time.
CAN is amazingly robust. Most CAN transceivers are fault protected to +/- 80 Volts. As with any communication bus, it is very possible to shut down communications by pulling it down or flooding it with traffic, but in the case of a vehicle like the Yaris, the CAN bus is not used for engine control, but rather to let the ECM get or share data with the other systems.
Old 05-25-2011, 03:49 AM   #10
henry33
Drives: yaris1.33
that is great that I cannot damage something ;)
this is specially designed to be used for canbus and the alarm has own software which will communicate and collect data from canbus. I think I will go for it since the installation is easy. the conventional alarm will cost 250 to install :(
Factory Alarm on my '08 Liftback is Too Sensitive! alex_melodymaker In Car Entertainment + Electronics (audio / video / alarm) 9 06-07-2011 04:21 PM
Alarm Wiring Advise Needed Lil Abner In Car Entertainment + Electronics (audio / video / alarm) 14 09-26-2010 11:11 AM
Keep your vehicle protected! sqcomp In Car Entertainment + Electronics (audio / video / alarm) 17 09-10-2009 03:02 AM
help me with my annoying alarm! misteo In Car Entertainment + Electronics (audio / video / alarm) 1 10-21-2008 02:49 PM
Rant! Damn car alarm installers, trying to rip me off!!!! W.A.S.P In Car Entertainment + Electronics (audio / video / alarm) 18 11-21-2006 10:18 PM
